Chrome seat switch covers
Old Dec 28, 2023 | 07:51 AM
  #76
MichiganStar's Avatar
MichiganStar is infamous around these parts
Mine are due on the 5th too. I got mine for the equivalent of 10 bucks so if they dont fit its not all bad.
Old Dec 28, 2023 | 10:03 AM
  #77
deckman's Avatar
I've had these for years. I think they look a little clunky and draw attention to an area I'd rather not notice
Old Dec 29, 2023 | 12:06 AM
  #78
seenastyle's Avatar
5 Year Member
seenastyle is infamous around these parts
Mine arrived today, 8 days earlier than expected. Unfortunately, they don't fit, they're too tight/small, but obviously a cousin to our controls. Unless I'm missing something, like that they're not meant to slide on top of the existing bodies as covers, but instead replace the existing bodies, or something like that.
Old Jan 2, 2024 | 03:55 PM
  #79
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
JUST GOT MINE IN!!! They do NOT fit!
Old Apr 16, 2024 | 12:08 PM
  #80
Prefurbia's Avatar
Found a solution
The chrome seat switch covers for the Land Rover LM2 that fit Aston Switches are seemingly not available. I ordered Chrome (Mirror) paint from Culture Hustle USA (it took three months to arrive), but with very thin and light brush strokes I got the chrome look very easily. I used a small model brush. I did two coats so far but one coat looked good, enough to do a few hundred seat switches from the small bottle. They suggested very light coats (shown is two coats).
Old Apr 16, 2024 | 02:51 PM
  #81
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Old May 2, 2024 | 12:29 AM
  #82
seenastyle's Avatar
5 Year Member
Interesting, thanks for sharing. So while it's called chrome / mirror, both its bottle and your finished product look brushed, am I seeing that correctly? Do your brush marks / directions / lines remain? If so, then I'd think the brush you use probably makes a difference, and you'd want to maintain the same brush stroke direction.
Did you paint these in place, or remove? Any masking tape used? Personally, I'd be too scared to try unless I could set up the perfect conditions to make sure every brush stroke was perfect, such that it would look closer to factory vs something I did in the garage. The good news is that those controls are not very visible and mostly in the shadows. So there's room for error unless someone stares at the point blank, which won't happen.
Old May 2, 2024 | 07:17 AM
  #83
Prefurbia's Avatar
Chrome Paint
The chrome looks very much like the brushed look of the aftermarket plastic overlays that used to be available for the Land Rover LR2 I used in the past. I tested the paint on some plastic items before brushing it on the switches. The application is extremely thin, so I did not worry about drops from the paint brush. It pretty much covered on one layer, but I used a few anyway. Because the brush had little of the paint I did not mask it but made sure I had plenty of light and was super steady with the brush. Unless you were right up close (as in the last picture) you would notice some imperfections. This image shows a more broad look of the interior. I doubt anyone would be looking so close to the switch to know it's a finish I painted on. Painting the bottom was tricky non masked.
Old May 19, 2024 | 03:02 AM
  #84
PhuketPaul's Avatar
PhuketPaul is infamous around these partsPhuketPaul is infamous around these parts
I modified a set of Rapide chrome seat controls to fit my 2006 DB9 Volante, there was a lot of rewiring involved but it all works fine (not using the lumbar support switch at the moment), I'm building a custom PCB for the next set.
Old Feb 6, 2026 | 02:16 AM
  #85
Spitfire980's Avatar
Spitfire980
So whats the latest link to buy from?
Old Feb 6, 2026 | 10:22 AM
  #86
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Upload this picture in google images and you will find the matching Land Rover units.
Old Feb 6, 2026 | 10:30 AM
  #87
Spitfire980
Already did, i found for the disco 5, Velar, RR and RR sport.
Couldn't find anything for the LR2 or freelander
Old Feb 11, 2026 | 05:39 AM
  #88
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
I think if you give Atlantic British/British Pacific (east coat/west coast, same company anymore) a call, or Rovers North, in Vermont, they'd be able to find these for you, especially if you know the year and trim level of the Rover you're borrowing from. I've never had a bad interaction with either company ordering parts in the past 20+ years of owning Rovers (we're on our fifth).
Old Feb 19, 2026 | 12:30 AM
  #89
Spitfire980
https://ar.aliexpress.com/item/1005001905042800.html?spm=a2g0o.order_list.order_l ist_main.5.bab81802Bcoj1M&gatewayAdapt=glo2ara
Tried this, doesnt fit, the search continues
Roxy18
BMW //M
Jun 17, 2011 06:19 PM
Bennylava
Cayenne 955/957
Oct 22, 2010 08:41 PM
ND4SPED
Feb 22, 2010 05:39 PM
Ski-Man
Nov 29, 2006 03:50 PM
BMW23LOVER
Audi
Sep 20, 2006 11:04 PM
