HELP !!! rattle upon starting for first 1-2 seconds
Old May 20, 2015 | 11:46 AM
sryan14610's Avatar
sryan14610 is infamous around these parts
I think I over revved my Vantage V8. I took it to my regular mechanic.. He is a good mechanic but he said I have to start with research to find out what is happening. The engine has a knock for about a second until the oil gets in (my guess and theirs). This happened the day after I accidentally hit 7700-7800 rpm for a second or so. It lonely happens when the engine is cold, and the oil has had a chance to settle.
Any advice or ideas? Thank you all for your help.
sryan14610
Old May 20, 2015 | 12:30 PM
telum01's Avatar
About the oil: Are you sure you've got the correct amount in it? There's a specific process for checking the oil level (it's in your owners manual)
About over-revving: The engine will shut off to prevent catastrophic failure from over-revving. If you start it up too soon after it shuts itself off, it'll be in a limp mode. I've done this twice myself lol.
Old May 20, 2015 | 01:28 PM
sryan14610's Avatar
re: rattle when starting up
Thanks for the information. I checked the oil as described. I was only doing 7800 rpm for probably a second. I shifted as soon as it did.. almost. The car seemed to run fine that day. The next morning and every cold start since it has the rattle? In doing a search I some mention of an oil pressure relief valve?
There are no check engine lights either. I had it Eurotuned about a year ago and only run 93 gas.
Scott
Old May 20, 2015 | 01:46 PM
Irish07@VelocityAP's Avatar
The oil pressure relief valve (or PRV ) will back off if there is too much pressure. There was a old bulletin about them causing noise.. But this was the same noise you would hear after just changing the oil.. Like a howling hone that goes away when pressure is built up.. Just it wouldn't go away and occurred all the time near idle rpm. Believe the old ones were metal and the fix was to replace it with a plastic one to stop the resonance noise from travelling...Nor sure this will be your fix
The rattle noise, is it like a valve train tapping noise?
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old May 20, 2015 | 03:01 PM
sryan14610's Avatar
re: noise upon starting
The mechanic thinks it could be. I don't know. it is so brief. I don't think it has any problem after starting. Does that rule out big problems? I don't know how they are going to diagnose this.
Old May 22, 2015 | 08:37 PM
It does rule out the PRV..
To diagnose, they will most probably remove the valve cover with the engine running to pinpoint the noise..I've had to do it a few times.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old May 22, 2015 | 11:18 PM
007AMV8's Avatar
007AMV8 has a spectacular aura about007AMV8 has a spectacular aura about
sryan14610
got a video/sound clip of the sound?
COBB Tuning
Mar 29, 2016 09:26 PM
shinjuku
Aug 29, 2015 09:59 PM
ritchrwi
Aug 29, 2015 08:27 PM
