Aston Martin DB9 GT breaks cover
Old Jun 24, 2015 | 04:42 AM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Here she is, the final edition before we enter the V8 Turbo era: http://www.autoblog.com/2015/06/24/aston-martin-db9-gt-breaks-cover/
Old Jun 24, 2015 | 09:01 AM
rohnin's Avatar
rohnin is infamous around these parts
Ooooh, a new infotainment system for the Vantage, too!
Old Jun 26, 2015 | 09:11 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
The V12 will stick around for a few years longer past the Jag V8 bites the dust.
Is this cheaper to a normal DB9 similar to Vantage GT being cheaper than the standard vantage?
Old Jun 26, 2015 | 10:35 PM
anton28's Avatar
anton28 has a spectacular aura aboutanton28 has a spectacular aura about
The end of an era. The V12 is the heart and soul of the db9/S/Vanquish. I don't see how this car will be the same with a TTV8
Old Jun 27, 2015 | 12:53 AM
MRY's Avatar
MRY
MRY is infamous around these parts
Maybe we will get lucky and AMG will donate some bi turbo V12 engines to squeeze into the DB9.... I would absolutely love one of those...!!
Anyway, the new Mercedes V8 bi turbo is good for 600+ hp so there will be plenty of power in the Aston version..
Old Jun 27, 2015 | 01:12 AM
anton28's Avatar
I'm definitely not talking down the v8tt by any means. It's an amazing platform! I've had a few AMG cars over the years and a huge AMG/MBZ fan. I just love the Aston V12. The AMG v12 is a much more efficient and powerful motor capable of 800hp and 1000tq with minor mods but it just doesn't sound the same as the Aston V12 Aston V12 just sounds so unique.
What they need to do is put the AMG v12TT in the Vanquish, somehow get it to sound like the current Aston v12 and then its on like donkey kong. Then the Aston brand will get the aftermarket support that it needs and we will see 1000hp Astons running around. There are a bunch of S/CL/SL65 guys running that power with relatively minor mods.
Old Jun 27, 2015 | 09:38 AM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
Here's to that!! I don't see why it couldn't wouldn't happen.
Old Jun 27, 2015 | 10:28 AM
MRY's Avatar
MRY
A buddy of mine has a Renntech CL65, and I have driven it to 320kmh in 1.5 miles on a speed event with a validated timing slip, and also more than 300kmh on the road, and it would be fantastic to have that kind of power in a DB9.
I am thinking of buying another DB9 and installing twin turbos on it. 1000hp is very attainable on the AM engine. The rule of thumb tells me that I can double the power and only put an additional 10% load on the components by keeping the peak cylinder pressure in line with good heat management. I need to finish another car project first though.
Anyway, I hope Aston gets the CL65 AMG V12TT engine, Bosch ECU, and ZF8 speed. I would definitely buy one of those and save myself all the hard work of building one..!!
Old Jun 27, 2015 | 06:38 PM
anton28's Avatar
I've looked in to a TT build for my DBS but haven't found a shop that would want to take the project on. Coming from a 1000hp and 1200hp vipers I'm very familiar what's involved but I don't know anything about the Aston platform and ecu to start piecing it together my self.
What would you run for engine management? I was told the V12 doesn't have a knock sensor which is a problem but I haven't verified this.
Old Jun 28, 2015 | 02:01 AM
MRY's Avatar
MRY
Hi Anton,
I want to keep the stock ECU's as I need the OBDII for smog in CA USA. This will require getting the MAFs flowed to get the airflow limits between 0-5V and see what they are to align with the power requirements. Apparently there are some people that have been able to get into the fuel and timing maps to modify them. The DB9/DBS use two EECV Motorola chipped ECUs with Spanish Oak code in a master/slave arrangement. (Ford units)
If the fuel and ignition map are hackable, then all the corners of the maps can be modified that are above the basic load ranges.
Anyway, if I were building something for off road operation, I would use a Pectel MQ12. An SQ6M12 is also fine, or I could also use a Motec 150 or M880. I have an M880 and an M8 for another build I am currently doing. Any of these ECU's save the M8 can handle DBW (electronic throttle bodies) and VVT on the DBS/DB9.
I'm not worried about knock control, as you can tune the engine to fail rich and have a good safety margin. If you need knock control to feel safer, then the M150, M880 or Pectel units can handle all of it as well as being on a CAN BUS. If you want to get excited, you can use in cylinder pressure sensors from Omega and control/monitor the peak pressure via these sensors and control knock much better than microphone based (piezoelectric) sensors.
Anyway, probably not the thread to discuss all these technical items. But, as I said, if AM went to the Bosch ECU with AMG TTV12's, then I would buy one and save the trouble of a build.
Best Regards,
Old Jun 28, 2015 | 10:52 AM
anton28's Avatar
Hi Anton,
Best Regards,
Great info! These are the type of thread discussions we need to see more of on this forum! I'm very familiar with Pectel and Motec both. I'll send you a PM.
Old Jun 28, 2015 | 10:01 PM
Capt Vanquish's Avatar
Capt Vanquish is infamous around these parts
I'm new in the Aston Martin world, with an 04 Vanquish. Have you guys ever talked with a place in England called Bamford Rose? Seems the guy running the place is an ex engine engineering type, from Newport Pagnell. He can talk all the pressures, lambda stuff and what ever else. I started talking to them about getting rid of the pos of a header system on my car. It looks more like a plumbing system for an apartment building!
Old Jun 29, 2015 | 06:29 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Look at the top of the page Bamford Rose is a sponsor here.
Old Jun 29, 2015 | 08:35 AM
telum01's Avatar
You guys should start a new thread for this discussion. It'll be easier for people to find and not take away from the OP's post.
Old Jun 29, 2015 | 05:29 PM
But is Anton and MRY aware of who they are? I've spoken with them briefly and read some of the information they've shared on others websites. Seems like a rocket scientist understandings of the AM v12. And this subject IS worthy of its own thread!
