Wheel speed sensor
Old Sep 5, 2015 | 09:16 PM
DetomasoGTS74's Avatar
Wheel speed sensor
My car recently lit up like a Christmas tree with ABS, traction control, DSC etc. fist I disconnected the battery to reset the ECU. Lights came back on. Next since I was on the original battery I thought it may be getting to its end of life and causing the electronics to go crazy. Dealer replaced and lights came back on. After running diagnostics, it came back with a wheel speed sensor issue.
I have a lift at home, does anyone know where the speed sensor is and how to remove it? I understand it may just need a cleaning.
Thanks!
Old Sep 6, 2015 | 03:11 PM
J doubleU's Avatar
There is multiple speed sensors. Do you have more information, specific code. If the dealer replaced the battery and found the fault still present. You should have had them repair it, then all you have to do is put fuel in and drive it!
Old Sep 7, 2015 | 09:42 AM
Believe code was 0050 but the technician said it was left rear wheel sensor. Obviously I would have had them fix it but all 4 lifts were taken and I could not leave the car.
Anyone have experience removing and cleaning them?
PenguiN
Sep 15, 2015 11:44 AM
Aug 20, 2015 12:17 PM
Aug 19, 2015 06:35 PM
Nissan GTR
Aug 19, 2015 02:11 PM
Lifeisgood2
Aug 19, 2015 10:02 AM
