V8V Roadster aftermarket backup camera install
Old May 10, 2016 | 10:45 AM
cpaulPHL's Avatar
cpaulPHL is infamous around these parts
Following the threads on here and in the FAQ, I bought the backup camera kit from VolvoTech.eu (absolutely fantastic experience and super-nice and responsive owner btw)
Wanting to do this slowly and methodically, I spent last weekend carefully removing covers and panels to make sure I knew where best to mount and thread the wiring. FYI I am NOT planning on the much more complicated front-camera install right now.
My question is (for others who have done this) best mounting point for the backup camera. The thread shows install procedure for a DB9 which allows the camera hole to be drilled in the panel just off-center of the license.
On my V8V, the only choice appears to be drilling a hole through the painted bumper cover panel immediately in the center of the license plate. The panels on either side (where the license bulbs are housed) are not horizontal, so I would need to fabricate a mount if I chose to install there.
Thanks in advance for those who have done this before and can best advise. Also, best (safest) way to drill the hole cleanly. It appears that the Aston factory backup kit is installed in perfect center ...
PS: I will post photos after I'm done to help others - perhaps I will add them to the FAQ thread. The location of the Nav unit is different in the Vantage Roadster (it's in the center under the tourneau cover, but luckily there is just enough room to the side for the backup module.
Old May 11, 2016 | 11:57 AM
cpaulPHL's Avatar
To further expand on my question ... I can either:
- drill a hole directly in the center of the rear bumper above the license plate OR
- build a mounting plate and install the camera slightly off-center (7.5cm / 3.5”)
If I install in the center, I will need to use the adhesive strip to secure the camera, as I’m unable to access the bumper to bolt down without completely taking the bumper off (something I don’t want to do).
If I install off-center, I don’t have to drill a hole, and I can secure the camera with a bolt to the mounting plate.
What do you recommend?
Thanks in advance… I’ve included a photo of the underside of the bumper above the license plate.
- Paul
Old May 11, 2016 | 01:26 PM
W126C's Avatar
W126C is infamous around these parts
Just curious, what year is the V8V? I don't have experience with this, but if I could avoid drilling a hole, that would be my way to go. This is something I hope to add to my DB9 when I get my hands on it.
Regards
Old May 11, 2016 | 01:53 PM
cpaulPHL's Avatar
It's a 2007. In the end, I've come to the same conclusion - I'm going to fashion my own mounting bracket to avoid altering the vehicle.
Given the wide angle of the lens and the large number of off-center aftermarket backup cameras that fit in license bulb sockets, so I can't imagine it is a big deal.
Regards
Old May 11, 2016 | 04:51 PM
cpaulPHL's Avatar
In the end, I decided to leave my car unmodified and not drill holes, instead fashioning a mount from 22 gauge steel. It fits perfectly just to the left of the right license plate bulb and is held in place snugly by the bumper and license bulb assembly above.
Again, I will add details to the FAQ thread once I'm done - I've been taking detailed photos along the way for my 2007 V8 Vantage. There are a few notable differences from the DB9.
alexhuth
Apr 1, 2016 07:53 PM
Cayenne_BG
Cayenne 955/957
Mar 30, 2016 08:15 PM
F430Spider
Lamborghini
Mar 30, 2016 05:49 PM
Gene G
Mar 28, 2016 06:32 PM
nvelicu
Mar 26, 2016 11:56 AM
