Remove interior door handle?
Subscribeit looks like it has to be pushed back up but I am not 100% sure... I will have to remove mine also over the winter months so if you find out how please let me know. Thanks
I think if you release the spring (seen in last picture) then you can push it out
Quote:
Figured it out. Spring has nothing to do with it as it turns out because the spring is merely held in place by the pin itself. Just grab a good pair of needle nose pliers and grab the pin here, and force it out (obviously in the direction of the bottle cap as the other end is closed off). Mine was a little stuck, so I actually took a sharp flathead screwdriver at the point marked with the arrow and tapped with a hammer in the direction going out.Originally Posted by handyman2009
I'm having the pulls and handles (which are easily removed by removing the spring mechanism once the pin is removed), door sills, exterior handles, exterior mirror caps, window switches and 20 other parts (including the speedster humps) skinned in real 2x2 twill carbon fiber.
Please show pics before and after great detail your going to on this
- Porsche Panamera 2 sets full interior Carbon fiber and Natural olive
- RSC MEMORIAL DAY SPECIAL - Aston Martin Carbon Fiber
- RSC Tuning Memorial Day Special - RANGE ROVER 11 PIECE CARBON FIBER TRIM KIT
- :: ECS Tuning :: ECS Carbon Fiber MK5 R32 Rear Valance - New Item !!!
