Adding water to battery
I live in Florida . It hard on batteries. So I added a good amount to the FX and thought I would check the Vantage. It seems I would almost have to dissemble stuff as if I was replacing the darn thing. Question can the water level be checked and if necessary added? It does not appear to be a sealed battery.
What car do you have? Modern AMs have sealed batteries so you can't (or at least it's not intended) add water to them.
i can't remember the last time i checked a battery's water level. :eek:
I am so young compared to you folks that when I think about battery and water I think about getting electrocuted haha
Originally Posted by blue2000s
(Post 4553210)
Not all batteries are sealed. If they are not, charging will sometimes evaporate the water levels in the cells. Periodically adding distilled water to keep the plates covered extends the life of the battery. Checked the water level on the fx a few days ago and the water level was so low the plates were exposed. Each cell took a fair amount to water. As the battery condition is so critical with the Vantage I though checking the water level in the battery was a good idea ( if you can) Apparently no one does this anymore ?? |
Looked at the battery, it has a vent tube which would indicate that it is not sealed?
Sealed and serviceable are two different things... There is a series of plugs on the top of the battery, you may be able to open them up. I haven't tried it, though.
https://static1.squarespace.com/stat...g?format=2500w |
The OEM batteries are serviceable, the caps unscrew. You can add distilled water if low. Or you can wait until it doesn't start then add aspirin to each cell for one last start.
[QUOTE=J Or you can wait until it doesn't start then add aspirin to each cell for one last start.[/QUOTE]
LOL hilarious |
Originally Posted by telum01
(Post 4553325)
(Post 4553325)
