Passenger side valve cover bolt - need help
Old Jan 13, 2017 | 11:24 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Anyone know a good way to take the rear most bolt off, I am talking about the lower one. There is a hose that sits right over the bolt and there is a bracket attached and the hose is so close, I cannot get a socket on it.
Old Jan 26, 2017 | 09:18 PM
randyb's Avatar
I had to remove the bottom pan to get to the bracket, that bracket is connected to several hoses, so I had to remove the tie straps holding the hoses to remove the bracket.
AM engineers must have received their training in Japan, because those straps were a PITA to get to, on a side note you do not have to remove the 2 firewall braces to remove the valve cover.
