How important are the three "loose" grille brackets on Vantage?
Old Mar 25, 2017 | 10:08 PM
Smoky's Avatar
Smoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud of
I've been wrapping my grille in carbon fiber vinyl. In the process I noticed three of the brackets that slot-in the grille are not actually attached to the car but just there it seems to add some rigidity.
I'm running a 4-bar setup. Everything seems pretty solid w/o the extra brackets and looks a lot cleaner up front without them. Are they necessary to maintain the grid on bumpy highways, or not needed? I like the idea of leaving them off if it won't create an issue.
Thx
ID:	472729   Click image for larger version
Old Mar 26, 2017 | 07:41 PM
era2076's Avatar
era2076 is infamous around these parts
That looks very nice - run it - you'll know soon enough if there is a problem.
chr
