Replaced Passenger side door window regulator AND
Found the adjusting bolt loose, the bolt above it was gone and of the 2 front bolts only one was tight. Missing bolt was once there, I could tell that from the bolt imprint on the frame.
Moral of this tale, if you here a rattling sound coming from your doors, check it out now and don't wait as I did.
