What did you do to your Aston today?
#316
What tires are you running? any mods? Did you have a mic wired by the exhaust for the video/audio?
#317
Car is practically stock (K&N filters being the only change that might impact power).
Tires: Michelin Pilot Sport 4S
Brakes: Porterfield R4
Brake Fluid: Motul RBF600
Video: GoPro Hero 5 Black
Audio: Tascam DR-05 with Purple Panda Lavalier Mic (with windscreen) taped to rear bumper
Overlay: RaceChrono Pro (Android) with Dual XGPS150A and OBDLink LX
I'll be at the track again on Wednesday and, if it doesn't rain (as is forecasted), I may try to tape the mic a little higher up--maybe just under the rear spoiler--to reduce some of the harshness.
#320
I mounted a new set of Forgeline GT1 5 lug lightweight one-piece forged monoblock wheels on my 2019 Vantage.
I think the rear can be lowered another 15mm but I'm worried about lowering the front because the wider tires might rub. Right now there is no rubbing.
I went wider with 275/40/20 F and 315/35/20 R (stock were 255/40/20 F and 295/35/20 R). I kept the same aspect ratio. I noticed the increased mechanical grip -- it feels quicker off the line with the wider rear tires and turn in is much improved with the wider front tires.
I think Forgeline got the offset spot on -- the wheels now sit flush with the fenders, giving the Vantage a more aggressive stance,
#321
gave my aston a thrashing up in the mountains yesterday... came up on a 997 Turbo and had no problem at all keeping up with him in the twisties... the straightaways though thankfully were pretty short which helped me keep pace pretty easily
this chassis is so well balanced it just grips like you wouldn't believe
here's the drive, I always go over and back... good times especially if you don't get any traffic on the geiger grade part, and the map does the road no justice!
#322
I replaced the stock nav screen in my 2011 AM Vantage S with a new high-res TFT screen, mapped the original nav system to it, added iphone mirroring, and added front/rear cameras for parking. I put a separate thread on this site for anyone interested.
#324
Set a new personal best a month after my last one. And with the Fabspeed X-Pipe installed, it now sounds like a proper supercar.
https://youtu.be/GK_XqnpOnJ4
Ron
#327
New Tires and Changed Rim Color
It was time for new tires and I decided to change the rim color to satin black at the same time.
I went with Pilot Sport 4s, got the wheels powder coated, and added black wheel caps.
#328
Careful when getting wheels powder coated. The heat from the process can anneal the aluminum and change it's mechanical properties.
#329
Wet sanded hood and roof
Let me start by saying I don't recommend anyone do this. You go through the clear coat and you're screwed.
So I bought a 2006 V8V late last year. Though I've been really happy with it for the most part, it did have some water spots on it. Wasn't too worried about it at the time as I've done some paint correction and have tools and product to take care of most things. But when I went after these with some chemical and mechanical means (heavy cut compound), nothing. After consulting a couple of experts, came to the conclusion that these are probably type 2 water spots and that wet sanding was probably the only option left. Little nervous about this as I had done very little wet sanding.
Read up on it and watched several videos and thought I would give it a try. I ended up wet sanding the whole hood and spot sanding the roof. About 2 dozen spots of different sizes on each panel...about 50 total. I actually end up doing each panel twice. Though the second time it was spot sanding only those spots that did not completely come out the first time plus refining my technique. I've got a Porter Cable random orbital buffer with 5" and 3" backing plates. I learned the buffer just does not seem to have enough power to remove the scratches left by sanding with the 5" backing plate and 5.5" pads. I end up just using the 3" backing plate and either a 3" or 3.5" pads.
Anyways, been working on this over the past month and finished up yesterday with a coat of sealant. Pics below.
2/3 of the hood done
Here it is complete after the first round. Did not do a close up as you just don't see anything except the regular paint.
