Sat Nav clips
Old May 1, 2017 | 11:39 AM
MrCLOS's Avatar
MrCLOS has a spectacular aura aboutMrCLOS has a spectacular aura aboutMrCLOS has a spectacular aura about
Sat Nav clips
Hey guys - went with the piano black waterfall for a change. Smooth sailing up until now.
Question: Is there a specific procedure/tool to re-attached the sat nav cover back to the back of the nav? It has 2 spring clips that I'm guessing somehow goes into the nav cover piece.
Problem: For the life of me, I have read a dozen threads on the subject but no one seems to be having a hard time on this... I'm losing my mind (and my fingers over here).
Thanks in advance - Carlos ('10 Rapide)
Old May 1, 2017 | 11:49 AM
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
The springs attach to the nav screen and to the cover (that's how they move together when the screen opens/closes).
Also, there are two different subframes, and you have to make sure the parts you have match up. There's metal and there's plastic, and they aren't interchangeable.
Old May 1, 2017 | 11:56 AM
MrCLOS's Avatar
Thanks Rich for always coming to the rescue.
I read about that and compared both covers (from the inside). They are identical.
Do you force the springs back into the middle plastic tab?
Old May 1, 2017 | 03:03 PM
M5Power's Avatar
M5Power is infamous around these parts
Hi Carlos,
I can't help you much with the sat nav clips, but I would be interested in your wood waterfall. Would you be interested in parting with it? If so, please PM me. Thanks, Andrew
Old May 1, 2017 | 04:18 PM
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
I had the same issue when I switched. Felt like I really had to bend the clips to fit but it turned out OK.
