06 V8V slow start in the morning?
Old Jun 27, 2017 | 11:47 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
68k miles and car is slow to start each morning after sitting for the night.. (ambient temp 80deg)
It turns over properly and battery & voltage are fine. But it somewhat sputters a bit and 'chugs' .. until fully firing up. On occasion takes a 2nd push of the start button. Car runs 100% fine otherwise.
I did replace the plugs.. (due at 70k) ... but that wasn't it. Really thought it would be.
Other ideas?
Old Jun 27, 2017 | 12:01 PM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
I'd check the starter. Replaced mine a year ago.
Old Jun 27, 2017 | 12:03 PM
EuroKip's Avatar
EuroKip is infamous around these parts
Could be check valve in fuel system loosing prime
Old Jun 27, 2017 | 12:55 PM
svre46's Avatar
svre46 is infamous around these parts
2nd for check valve....I am not sure about the Vantage but on many newer models this is built into the fuel filter assembly.
Old Jun 27, 2017 | 03:30 PM
embdenb's Avatar
Not sure how to do this on the Aston, but I would check the fuel pressure at the injectors. Fuel rail not holding pressure? That's your problem. Rail pressure ok then move on to something else
Old Jun 28, 2017 | 08:28 AM
This sounds exactly like what it is... I was going to guess maybe a fuel filter or something limiting initial injection.
Thanks!
Old Jun 30, 2017 | 08:27 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
Almost sounds like the fuel pump starting to go bad...
All answers given you make sense too...
Good luck
