DB 7 Rear quarter window
Old Jul 21, 2017 | 02:19 PM
sparr's Avatar
sparr is infamous around these parts
Im having a problem with the rear LH quarter light on my 1997 DB7 volante .
the right light acts as it should , i.e. goes up and down as the top is raised/lowered , but the LH doesn't budge .
The 2 relays have already been replaced , but to no avail .
It seems to me that this is a bit of an Aston Volante " glitch "??
Does anyone else have any relevant experience ??
Stephen
Old Jul 21, 2017 | 05:57 PM
J doubleU's Avatar
Check power and ground @ the motor the connector pins are pretty robust against poor connection/contact. Most likely fault is from lack of use and the motors flat spot. hammer time and or replacement if you can find the part.....You may try Piston Heads forum, Not much support for DB7 Vehicles here.
Old Jul 22, 2017 | 12:00 PM
XJRS Owner's Avatar
For DB7, forget PH. AMOC is by far your best bet at getting advice.
VID997
97
Mar 20, 2018 02:23 PM
