Aircom Failure in AM Vantage
Old Aug 2, 2017 | 10:08 AM
PhastAM's Avatar
PhastAM is infamous around these parts
I'm having an issue with the AirCom in my 2007 Vantage. The right vents are blowing cold air whilst the left vents are blowing hot air. This just appeared last month, and all checks on the system show refrigerant is full, and the compressor is functioning properly. Has anyone experienced this problem and if so, what is the cause and remedy. All help would be greatly appreciated.
Old Aug 2, 2017 | 10:51 AM
embdenb's Avatar
You problem is not the AC system, it's the blend flaps that control the air flow. You want to check flap motors and or air sensors under the dash.
Old Aug 2, 2017 | 10:52 AM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
I am currently experiencing HVAC issues and will post any remedy or solution when solved. Also, my compressor is fine and holding charge properly.
Old Aug 2, 2017 | 11:28 AM
PhastAM's Avatar
Thanks, I'll check it out
