Vantage door locking/unlocking issue resolved..
Old Sep 27, 2017 | 04:38 PM
Danno62's Avatar
Danno62 is infamous around these parts
Recently purchased a '06 Vantage. After getting used to things and driving I found I had a similar door lock issue to others that have posted.
My key FOB would not lock the drivers door fully, but I could with the key alone.
I just received and replaced the drivers (LHD) door module with a '07 used module and the locks now function properly.
P/N removed...6G33-13C791-AH
P/N installed....7G33-13C791-AA
Loosened door panel to access/remove puddle lamp plug.
Removed door panel enough to remove mirror/window plug.
Set door panel aside.
Removed door module assembly (four bolts) enough to remove the three plugs.
Removed and plugged in new/used module.
Plugged in mirror/window switches, tested, operationally checked ok.
Reversed procedure to install.
Reset windows by holding each switch separately in down and hold for 5 sec. then up to full up for 5 sec.
Door locks now function off the key FOB normally.
Hope this helps!
Old Sep 29, 2017 | 03:59 PM
svre46's Avatar
svre46 is infamous around these parts
Thanks for sharing! Hopefully this helps someone in the future.
Old Jul 5, 2018 | 08:29 AM
EAP's Avatar
EAP
EAP is infamous around these parts
Hi,
I have the same need. Does anyone know where I can get the module, part number 7G33-13C791-AA, as outlined by Danno62. Tried the web but no luck so far. Thank you
Old Jul 5, 2018 | 08:55 AM
handyman2009's Avatar
Veteran: Canadian Forces
Google is your friend.... here is what I found
sorry notice it was sold out.... if I find something I will let you know
Old Jul 5, 2018 | 09:28 AM
EAP's Avatar
EAP
Thank you and much appreciated. I will stay tuned, and will keep looking
Old Sep 11, 2018 | 03:12 PM
mackorbuddy's Avatar
mackorbuddy is infamous around these parts
I just had the same issue with the passenger door on my 07 V8V. The fob would arm the alarm and lock the driver door but it was still possible to open the passenger door and set off the alarm.
Before going after a new module, I’d try resetting it by pulling and replacing the fuse first. That did the trick for me and everything works fine now.
Old Sep 11, 2018 | 03:31 PM
EAP's Avatar
EAP
Hi there and thank you. Tried that but it did not work for me. The car is at the dealer as I write this note...
