2005 db9 front spring replacement - DIY tutorial / tips?
Old Oct 12, 2017 | 11:53 PM
Cvduk's Avatar
Cvduk is infamous around these parts
Hi,
I've got replace the front springs on my 2005 DB9 - just wondering anyone got a diy tutorial or tips ? As got the wheel off and looks tight to get the struts out
any help appreciated
Old Dec 5, 2017 | 01:30 AM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
Did you tackle this? I did my DB9 a couple years ago and I could help you out if you plan on taking it on. I'd also recommend getting the later model Bilstein assemblies as they are a direct fit and far better than the original parts from the early DB9's.
Old Dec 5, 2017 | 05:45 AM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
I would also highly recommend the VAP springs. The ride on mine is better and it doesn't sit too low. Workable height.
