Wrinkles in convertible top
Old May 9, 2018 | 05:07 PM
mjanis's Avatar
5 Year Member
mjanis is infamous around these parts
How do I get wrinkles out of my convertible top? Is there any way to prevent them other than never putting down the down?
Old May 9, 2018 | 08:14 PM
Arcadian's Avatar
5 Year Member
Arcadian is infamous around these parts
Wrinkles need steam
Folded with heat gain from sun will require steam for closed storage. Get a hand clothes steamer to take out the creases when parked in cooler garage.
Old May 9, 2018 | 10:36 PM
mjanis's Avatar
5 Year Member
Heat gain from sun
I am trying to understand this statement. So if the car has been sitting in the sun, and the top is hot, lowering the top under these conditions is what causes the wrinkles?
The car spent it's first 10 years in LaQuinta, CA which is near Palm Springs. It definitely would have experienced some sun and heat extremes. It was supposed to have been stored in a climate controlled garage, but probably got it's fair share of sun exposure.
As far as using steam on the top, do I need to worry about damaging the weather proofing of the fabric?
Old May 10, 2018 | 05:42 AM
Arcadian's Avatar
5 Year Member
If the top is down while parked in the sun and then stored closed in air conditioned space, the wrinkles tend to set reflecting the closed pattern.
Steam just the area with a good professional steamer to relax the fabric.
The Steam will strip water proofing, so it can need touch up, or wait to steam it before you re-apply water proofing for the whole roof.
Once you get it smooth, after driving with the top down, try closing the top while still out in the sun before parking the car in the garage.
Same problem here in Florida with heat, sun and air conditioned garage.
Old May 10, 2018 | 07:11 AM
XJRS Owner's Avatar
Unfortunately all Astons have the exact same wrinkling problem on the c-pillar area, even virtually new cars. It does tend to detract from the looks when the top is up. Poor design IMO. I had several Jag XJS convertibles and the tops never looked wrinkled at any spot, even after 20 years.
hkg1997
Mar 19, 2020 02:50 PM
KN14911
Sep 23, 2014 02:51 PM
M!!
Jun 18, 2013 05:19 AM
ukchris
11
Mar 9, 2008 03:35 PM
