How does it work...
Old Jun 15, 2018 | 09:32 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
How does it work...
How does the clutch work on The automated tranny? Like when sitting at a stop light. Does it disengage? Or does it slip and when you jump on the brake while creeping down the street doe it disengage or what? Is that why the clutch does not last as long as the manual?
Old Jun 16, 2018 | 10:07 AM
XJRS Owner's Avatar
Below a certain rpm it is fully disengaged and above a certain rpm it is fully engaged, and in between it is progressively engaged. So, at a full stop it is disengaged. There are other operating subtleties, but that's the gist of it.
Old Jun 16, 2018 | 12:04 PM
MRCW's Avatar
While i agree that at stop the clutch disengages, my habit has been to pull back both paddles at a stop to put in neutral. ..
Old Jun 16, 2018 | 04:55 PM
XJRS Owner's Avatar
Originally Posted by Redpants
Manually put it in neutral at full stop if you want the clutch to last its longest. Manually control the clutch if you want the car to drive its best.
How do you manually control the clutch without a clutch pedal? The clutch won't last longer whether you put it in neutral or not; disengaged is disengaged. If you are talking about the throw out bearing, that's a whole different matter.
Old Jun 16, 2018 | 05:47 PM
MRCW's Avatar
Ding ding ding...!
Old Jun 17, 2018 | 06:13 AM
embdenb's Avatar
You are correct about the benefit to the throw out bearing. That said there is some benefit to the clutch assembly if the car is put into neutral. By releasing pressure on the clutch’s pressure plate you are prolonging the life of the pressure plate itself.
Clutch won’t last longer but the pressure plate will (smile)
Old Jun 17, 2018 | 09:17 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Which is exactly the same reason that you shouldn't sit at a stop light with your foot on the clutch in a manual car.
jtorrebl
Mar 12, 2018 11:07 AM
