Lifting a Vantage
Old Jun 25, 2018 | 09:35 PM
Denny 6.53's Avatar
Denny 6.53 is infamous around these parts
Lifting a Vantage
I am going to bring a two post lift home from work. The pads are about 4" high and my 2011 V8V S appears to be not much higher. I can see driving up onto 2x10's, but I wonder if that would get the car high enough for the lift pads and pucks of some sort to clear the side skirts?
Has someone already worked this out? Thanks
Old Jun 25, 2018 | 11:37 PM
Graze's Avatar
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
denny
Ive found that all you need is some low rise ramps to get the front up about 80-100mm then the arms & pads fit under (just)
like these
https://www.ebay.com.au/itm/5000kg-Low-Profile-High-Quality-Car-Ramps-Pair-70cm-Long-Antiskid-Service-Ramp/192292704376?hash=item2cc589d078:g:0s4AAOSwrWVbK63 z
Graze
Old Jun 27, 2018 | 08:23 AM
Denny 6.53's Avatar
Hello Graze,
I found the ramps that you show in the link. Do you have any trouble with them moving while you are trying to drive up on them?
Old Jun 27, 2018 | 08:25 AM
Denny 6.53's Avatar
Matt,
I will be getting in touch with you. Do you have the S model pucks in stock?
Old Jun 27, 2018 | 03:50 PM
Graze's Avatar
Originally Posted by Denny 6.53
Hello Graze,
Denny
Unlike the higher metal ramps the plastic ones do not move as you drive up onto them
I use them at home when I need to and take them to my mates workshop if I am using his ramp
I also have Matts lifting blocks which are the most useful thing I have purchased for the V8V - highly recommended
Graze
Old Jun 27, 2018 | 08:31 PM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
I have a set of the pucks for my VantageS
They work perfectly!
Matt had to redo the original I ordered based on a clay molding from the S, and he was quick, responsive, and communicated the entire process end to end!
Highly recommend his services and lift pads :-)
Old Jun 28, 2018 | 11:20 AM
Denny 6.53's Avatar
Thanks to everyone. I bought Graze's ramps at Summit Racing (one exit away from me) and Matt's pucks are on order. My lift gets moved on Wednesday, which of course, will force me
to clean out the garage (28 x 48 x 12 high) and then I can go to work.
jox
Ferrari
Jan 7, 2008 12:24 PM
hjacobs2000
Nov 30, 2007 04:15 PM
sechsgang
Sep 28, 2007 07:49 AM
sasportas
Mar 16, 2004 07:11 AM
