Brake caliper help
Old Oct 17, 2018 | 04:13 PM
handyman2009's Avatar
Veteran: Canadian Forces
Here is a nice kit also Brake Caliper Piston Tool Kit I always use the tip from the long nose plier and works perfectly fine
Old Oct 18, 2018 | 06:47 AM
Denny 6.53's Avatar
Denny 6.53 is infamous around these parts
Thanks guys
Old Nov 3, 2018 | 10:57 AM
DetomasoGTS74's Avatar
Just following up to close this out. Advice above was correct (thank you). I had not wound back the piston, thus the gap. I used the needle nose pliers to rotate it back in. I noticed a massive chunk missing out of one of the ebrake pads and one side was worn down to nothing so I ordered new ebrake pads from Rich (redpants) that he helped develop. Embarrassing squeak is now gone and all is right again.
Old Nov 3, 2018 | 11:03 AM
Glad you got it sorted out
Old Nov 3, 2018 | 11:27 AM
appreciate your help!
Old Nov 3, 2018 | 11:29 AM
Was happy to help. Some days it will be me needing help from someone here.
Old Nov 8, 2018 | 12:29 PM
Irish07@VelocityAP's Avatar
FYI: When you get the new pads, chafe the edges 45* and it will avoid getting a squeak noise on these after car sits for awhile. Hehe..and don't forget to wind back the piston completely before installing the new set.
Old Nov 8, 2018 | 07:40 PM
Thanks Chris, the pads Rich (Redpants) sells have the 45* already there!
boyg
Jul 26, 2016 08:08 PM
ltdodge
May 6, 2015 01:14 PM
AP328
Sep 15, 2012 12:38 AM
yellowbmr
Aug 29, 2004 07:47 AM
