Finally took delivery, WOW!
Old Dec 21, 2018 | 04:13 PM
DonRW2007's Avatar
DonRW2007 is infamous around these parts
Congrats
Nice, and a very low price. If those are original tires, I’d stay well south of 145 (like 80 max) until you put some new shoes on...
Old Dec 21, 2018 | 04:30 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Looks like a great deal on a very nice car. I’m on my second Vantage and it has become one of my favorite cars. Enjoy your new toy and welcome to the forum. These guys are always willing to help with any problems or advise that you need.
Old Dec 21, 2018 | 08:03 PM
TarHeelVantage's Avatar
TarHeelVantage is infamous around these parts
Originally Posted by Hedged
You are probably overdue for Michelin P4S if those are OEM Potenzas! And do yourself a favor and look into a convertible top protectant like 303. Awesome car for the new year
Fortunately these aren't OEM- manufacture date code shows 2012, so coming up for replacement, but not in dire straights by any means. Thanks for the info re: 303- I'll get right on it!
Old Dec 22, 2018 | 07:47 AM
Aston502's Avatar
Aston502 is infamous around these parts
07 Aston
Have the same interior in my 07 and my car is Tungsten silver. I also have the sport shift trans.
Old Dec 22, 2018 | 11:53 AM
MRCW's Avatar
Depending on where the car was/is 5-6 years max on tires for High performance cars
Old Dec 22, 2018 | 04:31 PM
Viper98912's Avatar
5 Year Member
Viper98912 is a jewel in the roughViper98912 is a jewel in the roughViper98912 is a jewel in the rough
Grant is awesome; I hope to be able to buy a car from him one day.
Old Dec 23, 2018 | 04:33 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
2nd!
Get those tires off that car, STAT!
At 2012, you're at the 6 year line now.
Old Dec 23, 2018 | 08:45 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
The tires I just replace were 07's, they had a little dry rot but I replaced them because I was under 1mm on the rears. When I bought it 2 years ago it had the original 09 tiers [2010 car], I only replaced them when I got down to 1mm on the rares and they saw 140 several times. I'm not saying don't change the tires if you're ready, I'm just saying some put too much emphasis on what year they were made
Old Dec 24, 2018 | 03:21 AM
Viper98912's Avatar
5 Year Member
I'm going to disagree with this statement here.
As tires get older they get harder, so the amount of traction they have reduces significantly (think hockey puck or tupperware, instead of grippy tire). Now, there are many different factors that go into it (actual compound types, the amount of UV that the tires have been exposed to, etc), but in general the rule is about 7 years max.
I unexpectedly tested this theory a few years ago when I was trying out a set of wheels on my car. I wanted to compare the look (they were the same size and similar weight) so I loaded them up on the passenger side only and went for a drive. The car was definitely more squirley, a little more sloppy, and I was definitely breaking one side loose when doing some hard acceleration/turns/braking. I didn't think much of it at the time, until I got home and it all clicked in my head.
So yes, it's not just dry rot you need to be worried about.
Also, down to 1 mm is pretty dangerous. With even just a drop of rain, a rut in the road, or the slightest of belts showing, can be dangerous.
To each their own, just my opinions for others.
Old Dec 24, 2018 | 08:15 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
At least tires are not too expensive for this car.
Old Dec 24, 2018 | 09:04 AM
5 Year Member
Never put one type on one side only..
Hard old tires spin easy, drift easy, and are loads of fun. The ride is a little harsher but that's life. I'll be pulling my transaxel next week to have it pulled apart and diagnosed because where my Bridgestones would run sideways for 40 yards the new Michelins got violent tire shake and the rear has been grumbling ever since. Hopefully after a few good cold cycles they get less sticky and I can have some fun with them again.
Old Dec 24, 2018 | 02:01 PM
MRCW's Avatar
they are the only thing that connects you to the road and the most important safety feature of the car. . anyone that lets tires down to 1mm and proud of it doesn't need to be commenting about tires
Old Dec 24, 2018 | 02:32 PM
5 Year Member
I don't remember saying I was proud of anything, I'm giving a different point of view. Anyone who changes their tires because they only have 4mm left is missing out on 2mm of use and shouldn't comment about others choices. I started making a decision on tires at 2mm but they got to 1 before I decided, ordered, and had them installed. The fronts still had 5mm which is half depth.
If at any point I thought the car wasn't safe I would have changed the tires, The tires had tons of hard cornering grip, the only drawback was in the wet and that wasn't because of tread depth but because they were hard from too many cold cycles, so I wouldn't push it hard in the wet except to throw the rear out when I felt like it. Same in the dry, they'd spin so easy you could throw it around a corner anytime you wanted. I would highly suggest not doing that with new PS4S's as they are very sticky when new and I did not anticipate they'd munch on my transaxel. I'm sure they'll probably get harder over the winter but I won't be as likely to try and make them spin until I know they're not going to have eat box for lunch again.
Old Dec 24, 2018 | 02:38 PM
5 Year Member
BTW the first V8V I flew to Delray Beach to inspect, buy, and drive back to Jersey and 1mm in the outside of the rears and 0 on the inside, but had lots of undisclosed rock chips, a clackety engine, and 1 taillight didn't work, so I passed on the car.
Old Dec 26, 2018 | 07:06 PM
DonRW2007's Avatar
Tires, and congrats on purchase...
I think I was one of the first to comment on older tires regarding Tarheels’ new Aston. I feel like I owe an apology for inadvertently hijacking his thread...
i do believe that tires are the least common demoninator wth respect to performance, safety, and overall driveability. I’m no slouch when it comes to driving, but at 60, with reduced reflexes, and not wanting to go to jail in a state that outlaws radar detectors, I drive my V8V fairly conservatively. I was really uncomfortable with the feel of the original tires on my car. They were “original” for sure, being approximately 10 years old on a low mileage car. First “upgrade” was a set of new Michelins, and I was astounded at the difference. Best ~$1100 I have spent on the car to date.
DRW
