Clutch self-adjusting tool for Velocity AP
Old Mar 10, 2021 | 03:06 PM
Patrick Fitzhorn's Avatar
Patrick Fitzhorn is infamous around these parts
I have a Velocity AP Twin Plate Organic Clutch & Lightweight Flywheel kit for ASM (Sportshift). The instructions require the clutch to be compressed with kit: www.amazon.com/Chameleon-CHA3061-Clutch-Tool/dp/B08B8Y2B8M
Unfortunately, that kit is no longer available. Has anyone used something similar to compress the twin-plate clutch for installation? If so, what did you use?
Old Mar 11, 2021 | 07:23 AM
Ashman_E's Avatar
Ashman_E has a spectacular aura aboutAshman_E has a spectacular aura about
I know nothing...
I'll preface this by saying that I know nothing about these clutch tool kits, but I do have "mad search skilz" and from what I can tell, one of these may work...
https://www.amazon.com/8MILELAKE-Self-adjusting-Components-Universal-SAC/dp/B012FC7B7U
https://www.amazon.com/Adjusting-Assembly-Universal-Alignment-Setting/dp/B08FBCMGH5
If you use the search term "Clutch Alignment Tool, 38pcs Universal SAC Self Adjusting Clutch Assembly Tool" on Amazon you get links to about a bazillion of the same tool kit, probably all being shipped from China.
If someone can confirm for you that this one would work, then you have a ton of options.
Note that none of these look to be as high of quality as the Chameleon kit. However, if it gets the job done, then I guess it doesn't need to be heirloom quality... Not like you'll be changing clutches monthly or anything.
Old Mar 11, 2021 | 01:16 PM
handyman2009's Avatar
Veteran: Canadian Forces
if you do a search someone build their own and it didn't look too complicated
Old Mar 11, 2021 | 02:42 PM
Got it - thanks. Looks like any kit with a 3-lobe plate and M6 long flywheel bolts will work.
pwdrhound
Feb 7, 2017 10:05 AM
z06801
Apr 22, 2013 11:37 AM
GT-Silver
Aug 4, 2011 01:59 PM
MCM97
Jun 12, 2008 08:17 AM
