20 inch wheels
Old Apr 7, 2021 | 08:06 AM
Bankswood's Avatar
Bankswood is infamous around these parts
20 inch wheels
I'm considering going from 19 to 20 inch wheels basically because the wheel I'm considering only comes in 20. I have a 2006 DB 9. Anyone running 20 inch wheels? If so any fitment, rubbing, etc issues?
TIA
Old Apr 7, 2021 | 08:30 AM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Bankswood, I have a set of 20's ( Michelin's ) I run from time to time on my 2007 DB 9. No fitment issues at all. Make sure the wheel hub / off set of the wheels you buy is the correct size. I did have to use a different lug nut for my wheels. Speed odometer is off about 2MPH.
Old Apr 7, 2021 | 03:40 PM
MAUMAU's Avatar
MAUMAU is infamous around these parts
07 -
When you moved to the 20” wheels did the ride quality suffer at all?
I contemplated trying 20” wheels but was told that the ride gets a lot bumpier.
Thanks.
Old Apr 7, 2021 | 07:46 PM
Originally Posted by MAUMAU
07 -
Thanks.
No.
I believe the tires make the difference in the ride. I have newer Michelins on the 20's. My 19's actually are a little stiffer, thus bumpier, due to age. I plan to replace the 19's by the summer. A lot of Astons don't see a lot of miles each year so Astons with 7 or 8 year old tires are not uncommon. Older tires with low miles may have great tread but the sidewalls become stiff and effect the ride in my opinion.
Matt Barnes
Nov 3, 2020 07:20 AM
Fuzzo
Cayenne 955/957
Feb 19, 2016 03:11 AM
mikhail1
Cayenne 955/957
10
Oct 9, 2012 03:53 PM
ukgt2
Nov 29, 2010 10:37 PM
