Vanquish Touchtronic 2 vs. Toucht 3
Old Oct 21, 2021 | 03:44 PM
Lual's Avatar
Lual is infamous around these parts
Hi
is the Touchtronic 2 so much worse than a 3 ? I have heard several times that they are like day and night, but, enough for the T2 to become a No Go?
thanks
Old Dec 30, 2021 | 03:32 PM
lightguy's Avatar
lightguy is infamous around these parts
Originally Posted by Lual
Hi
thanks
Bump !
Newb here...
Is this referring to the 6 speed transmissions in the 2014s vs the 8 speed in the 2015+s ?
If so I have the same question.
Old Dec 30, 2021 | 04:19 PM
Lual's Avatar
Originally Posted by lightguy
Bump !
Newb here...
Correct, this was the question.
Old Dec 30, 2021 | 04:27 PM
dpath's Avatar
5 Year Member
dpath is infamous around these parts
I found the ZF 8 speed more responsive and a better match for the Vanquish’s V12 but the 6 speeds are still excellent cars and less expensive to buy. I also preferred the stiffer suspension and Bosch ECU’s on the 8 speeds. My best advice is to test drive both and see if the difference is worth it to you. Good luck in your search.
Old Jan 2, 2022 | 05:39 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
The big difference between the 2 is that the 8 speed has better MPG, acceleration and top speed.
topgun
Dec 24, 2012 01:18 PM
powerstar
Jul 29, 2008 11:58 PM
