What do these codes mean
Old Nov 15, 2021 | 08:26 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
What do these codes mean?
I have 2 new front o2 sensors in transit. The are OME. Any information would be helpful. Thanks in advance.
Old Nov 15, 2021 | 08:41 PM
Argus's Avatar
Another….
Here is another:
Old Nov 16, 2021 | 06:51 AM
J doubleU's Avatar
Your on the right track, replacement of both should solve your issue.
Old Nov 16, 2021 | 07:15 AM
acole's Avatar
acole is infamous around these parts
It looks like your right side (as you face the engine, left side as you sit in the diver seat) O2 sensor is going bad. Sensor 1 is the one in front of the cat that helps control fuel trim, so it's important that you replace it. The P1000 code is pretty standard and will clear when you let the ECU run through its full cycle of emissions checks which takes something like 30 seconds or 2 minutes. It may need that sensor to be in working order for it to clear, but I wouldn't be worried about that one.
Cattman
Mar 6, 2018 03:38 PM
Mr. C4
Feb 16, 2012 04:34 PM
Mr. C4
Jul 31, 2011 02:49 PM
Hogapalooza
Sep 23, 2010 11:29 PM
drewTT
Jul 27, 2007 11:40 AM
