Stuck Handbrake
Old Apr 28, 2022 | 10:30 AM
LGsmile's Avatar
LGsmile is infamous around these parts
Stuck Handbrake
My 09 V Roadster has a sticky handbrake that doesn’t always release well at all!
What’s the best way to fix it?
Old Apr 28, 2022 | 07:00 PM
J doubleU's Avatar
Check the material on the hand brake pads, make sure adjustment of cables are even (# of threads or distances similar) how high or how many clicks at the lever? 5-7 should be in the hunt for correct adjustment. Sticky button or dry mechanism at handle. 1st thing to check is your procedure as some people are not used to the left hand. Sit on the sill and try your Right hand and see if that changes.
Old Feb 12, 2026 | 03:16 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
Originally Posted by J doubleU
Check the material on the hand brake pads, make sure adjustment of cables are even (# of threads or distances similar)....
Do you want more or less threads showing to make it tighter (less clicks)?
Old Feb 12, 2026 | 07:37 PM
J doubleU's Avatar
Go big my friend. 22mm nut and you can count threads or use the wrench to judge distance for a quick check. Most stock build are started around that 22ish mm.
So try 25-30mm. Word of caution. Be aware of the inner pads as they tend to wear quicker.
goto35
Nov 3, 2016 05:47 AM
Tommy D
Jun 23, 2016 11:30 AM
JimB_MN
Apr 15, 2012 05:51 PM
007AMV8
Jun 9, 2010 04:45 PM
Fluid987
Dec 26, 2008 09:07 PM
