Aston Martin DBS - rear wheels shuddering at highway speed
Old May 4, 2022 | 04:01 PM
DBS down under's Avatar
DBS down under is infamous around these parts
Hi all, my Aston Martin DBS has developed a shuddering in the rear of the car (feels like mainly left rear) that's only occurring at highway speeds. Wheels are balanced, Pirelli tyres and wheel alignment are only 3,000km old and was occurring even before I installed wheel spacers. Has anyone come across this and what might be possible parts/solutions to resolve? Car has 36,500km mileage in total.
Old May 4, 2022 | 04:47 PM
XJRS Owner's Avatar
Check not only the balance on all 4 tires, but road force as well. Tires can be balanced but still impart too much force to the suspension every revolution. The shuddering you feel can come from the front tires equally as well as from the back. That’s why you need to check all 4 even if it feels like it’s coming from your seat area/back.
Old May 4, 2022 | 05:47 PM
61mga's Avatar
61mga is infamous around these parts
a tire can be out of balance due to manufacturing flaw. i recently had a tire's tread separate from the casing. a big bump developed in the tread, i didn't know what was going on, so i took the car to big-o tires to have a alignment done. ...hoping that that would fix the problem. they called and said the tire was about ready to explode. i told them to mount the full-sized spare on the car.
i eventually had to get a new spare, of course.
IOW, i would recommend visually inspecting the tire(s).
Old May 5, 2022 | 07:54 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
It could be a result of the tire internally separating. Is there a chance that the wheel is slightly bent? Check the shock absorber and suspension on that side as well.
Old May 8, 2022 | 06:38 AM
Stucat's Avatar
5 Year Member
Stucat is infamous around these parts
Just an idea. Do you know anyone with an extra set of tires, or a real, real good friend that let you swap, theirs for a test ride. That would at least tell you if its your tires
Old May 8, 2022 | 11:45 AM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I had a couple of years back 2 of what I can only call oval new tires on my truck..sent back and we’re replaced..it can happen..
Old May 24, 2022 | 05:23 PM
Thanks everyone, turns out they were my Adaptec wheel spacers according to the dealer. Motorsport Tech confirmed they were manufactured with a 69.8mm centre bore instead of 68.1mm so are reissuing.
DBS down under
May 3, 2022 06:09 PM
VegasFerrariLVR
Mar 17, 2021 11:17 AM
Curated Content Editor
Apr 15, 2020 09:43 AM
Sep 4, 2018 10:03 AM
Q8_TwinTurbo
Aug 18, 2006 02:34 AM
