No trips vs. short trips - which is worse?
Old May 27, 2022 | 02:39 PM
  #31
Speedraser's Avatar
Speedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond reputeSpeedraser has a reputation beyond repute
Originally Posted by SLVRon
Thanks for that video link - hadn't watched that one for a while. There's a subtle difference between what you have and what Mike describes - he talks about using the clutch (or brake for sportshift) as a switch. So you use the clutch to crank for 5 seconds, then off for two to avoid the starter overheating, then on again etc. until the oil pressure light goes out. Then you can lift the gas pedal to start.
Yep, I'm sure that works too. Usually 5 seconds is enough for the light in my V8V to go out, so I don't need to cycle it again. If I do, I may try it.
By the way, in the video he says this doesn't work on the gen 1 Vanquish. That's wrong -- it does. I've done it with my '05 Vanquish S. The oil pressure light takes longer to go out, perhaps because the V12 has a wet sump? Or maybe it's just a matter of where the pressure sensor is?
Randy V
Bentley
Feb 23, 2021 10:53 AM
007V8Vantage
May 9, 2018 01:24 PM
irvineboy
Maserati
Jun 26, 2012 10:25 PM
ShawnBoston
Jun 14, 2012 02:48 PM
bayareaferrari
May 29, 2007 10:18 PM
