Aftermarket CoilPacks
Does anyone have experience with these Amazon coil packs? https://www.amazon.com/8G43-12A366-AA-Ignition-Martin-Rapide-Vanquish/dp/B0868ML8QK?th=1
I need to replace the packs on my 2011 V12V. Does anyone know where I could source an equivalent one (I understand its a Ford part) without me having to go the AM OEM route?
Any help would be greatly appreciated!
Alibaba has some that people have recommended. NGK told me they were oem but they can not sell them to general public. AM has a deal that NGK can only sell to AM. NGK told me that is not uncommon.
I have used coils from a company called NTY over the last years and I find them very good for the EUR 30 p/coil I spend on these. Mind though, The ones I used are the 2-pin type (AM number 4G4E-12A366-AA) and have number NTY ECZ-FR-028. Not sure if they have the later 3-pin coil which you need but if you come by this brand I can highly recommend.
As always no affiliation with this company whatsoever.
I bought those for a rebuild of a DB9 I bought. After getting everything back together, one of the cylinders was not getting a spark. I had to pull the rocker covers back off anyway, so I swapped the "bad" coil pack position and just got it all back together today. Waiting for RTV to dry and will test tomorrow to see if the coil pack is in fact bad.
I'd be reluctant to buy Chinese products from AliExpress, but looking at the listing, it shows Japan as the country of manufacture origin. I wonder if that means they are NGK?
