Convertible Top Module
Old Sep 20, 2023 | 11:42 PM
sprinter's Avatar
sprinter is infamous around these parts
Hi all. I have an AM V8 Vantage convertible and the top module has failed. I have some thoughts, but does anyone have any ideas? Thanks!
Old Sep 21, 2023 | 08:16 AM
Senatorblutarsky's Avatar
Senatorblutarsky is infamous around these partsSenatorblutarsky is infamous around these parts
I just sold my 2007 V8V Roadster. I have a brand new roof control module that I bought from Repants but didn't end up needing. I'd be happy to sell it at a discount if you want it.
But I purchased it because the roof would not move and I was getting a warning like 'roof movement not possible'. But before I installed it I replaced the fuses for the passenger door windows which had also stopped working. Once I switched the fuse, the roof worked! I would try that first and if it doesn't work then you will probably need to install a new RCM. If needed, it's not that hard to do.
Old Sep 21, 2023 | 12:27 PM
charliefore's Avatar
5 Year Member
charliefore is infamous around these parts
The third time I replaced the CRM I brought it inside the trunk where SS module and tire kit are located. Less harsh environment and easy to disconnect if it fails.
Just disconnect and pull wires inside trunk. My car was not driveable if CRM failed. 90,000 plus miles since last replacement at 50,000 miles.
Old Sep 22, 2023 | 04:15 PM
So you have 140,000 miles on your car? If so, well done sir!!!
Old Sep 22, 2023 | 11:11 PM
sprinter's Avatar
Hi, Senator. How much do you want for the CRM module?
Old Sep 23, 2023 | 08:17 AM
5 Year Member
Yep, just picked up a big brother DB11 for another go around as well.
Old Sep 23, 2023 | 11:26 PM
sprinter's Avatar
Senator, are you still interested in selling your CRM module?
VantageS
Aug 29, 2025 02:24 PM
Denny 6.53
May 8, 2020 12:15 PM
goto35
Dec 19, 2018 01:12 PM
robertwroth
Mar 1, 2016 12:22 PM
