V8 Vantage Headlight gap...help!
Old Feb 12, 2024 | 01:53 PM
likwidplastik's Avatar
likwidplastik is infamous around these parts
Just picked up a beautiful 2010 V8V last week.
Passenger side turn signal is out, so I'm going to take it out this week and get the circuit board checked.
I just noticed that there is quite a large gap between the headlight and bodywork on that side (see pics).
I've read that the mounts are prone to cracking/breaking.
Anything I should check once I take the light out?
Old Feb 12, 2024 | 06:58 PM
J doubleU's Avatar
The front mounting is aluminum and is adjustable, so when you remove the headlamp you should understand how it works for alignment to the body panel. Hopefully you can get the lamp board repaired. There is several threads about it if you search.
AMTas
Feb 13, 2021 06:13 AM
LotusJPS
Jan 16, 2020 04:35 AM
Pmallhi
Mar 11, 2016 04:25 PM
XWCGT
Sep 24, 2015 10:26 AM
midtownlandman
Sep 3, 2015 01:17 PM
