SRS Airbag Service Urgent
Old May 20, 2024 | 04:32 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
This is the tool I have to reset some BMW SRS faults.
For later models, I can reset some cars with my Autel.
Old May 20, 2024 | 05:18 PM
volvodrummer's Avatar
volvodrummer
Originally Posted by brightoncorgi
I just got my car inspected and now have an error message "SRS Airbag Service Urgent". Any ideas what this could be? I was unable to find/clear it on my Foxwell.
the fact that you have other warnings coming out of nowhere makes me think battery rather than unplugged SRS module/lead. They’d really have to screw up to do that during a state inspection.
depending on your scan tool level of sophistication, you can try calling the car an ‘06 Volvo XC90 to access the SRS system.
Old May 21, 2024 | 05:26 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I'll give that a try today. Thanks.
Have a karting race tonight, so putting some miles on the car tonight hoping the battery will fully charge. On the CTEK since yesterday.
Old May 22, 2024 | 09:30 AM
5 Year Member
Only the SRS light remains. I haven't had a chance to see if I can do the Volvo hack. Hopefully later today.
Old May 29, 2024 | 05:25 AM
5 Year Member
Brought the car to the dealership to look at. Ends up being I need a rear driver side door air bag!
Old May 29, 2024 | 06:14 AM
BWings's Avatar
5 Year Member
Glad you're getting it sorted. When SRS detects a failure it basically shuts down and the dash warning is a message to the driver that air bags, in the case of an accident, do not exist until back up reset and running.
I am on a dozen different car forums. In the last few years there has been a rash of "It's the Battery" to describe practically any failure. It's become the modern day "Electronic Elixir". I am not saying that a failing battery is never the problem, but it seldom is. Too often, owners jump on this and replace the battery which is a lot simpler than diagnosing and fixing the problem. After that wasted step, the real problem still exists.
All the Best
Old May 29, 2024 | 07:02 AM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
So you are aware, I also had a rear side door airbag issue on my Rapide, but it wasn't the module (took the door apart from the inside to check and confirm). I could even monitor the SRS ignitor resistance varying wildly..... while i was opening the rear door. It turns out there's a bit of tension in the harness rubber covered wire harness that does a 90 degree and enters the body between the front and rear door, and I could manipulate it (push, pull , twist) and get it to clear the code as the resistance would go back inline. Turns out that wiring component is a bit problematic for the Rapide, it could be your issue.
Old May 29, 2024 | 07:23 AM
5 Year Member
I've replaced a door module already. The wiring does not have enough length to it apparently. A few years back they were able "repair" it, but that only lasted so long. I want to say last year I replaced the module.
The dealership said they tested all the wiring and narrowed it down to the airbag itself. The airbag requires special shipping from the UK. I'll be driving around with no door panel for a week or so.
Old May 29, 2024 | 08:03 AM
Sounds familiar!
Old Jun 3, 2024 | 08:48 AM
volvodrummer
I have personally and or second hand never heard of an air bag randomly going bad. My bet is that they get the new bag in and realize that didn't fix it. Prepare for new door harness.
Old Jun 3, 2024 | 08:57 AM
5 Year Member
I've replaced a door harness before the symptoms were different. They said they tested all the wiring and narrowed it down to the air bag.
All the experienced tech's at the dealership no longer work there. Everybody is brand new for both AM and Lotus. Recently trained and certified FWIW.
Old Jun 3, 2024 | 12:30 PM
volvodrummer
Anything's possible. I guess if that door harness has been replaced already it's unlikely it's failed again so soon. That's a bummer about the change over in dealer techs. Good that they'll be up to date on the current product but I wonder how they'll handle a quirky problem with an older car.
Old Jun 3, 2024 | 12:48 PM
5 Year Member
Need to find out where a couple of them have landed. Could be closer to my house and/or they charge less an hour than the dealership.
Old Jun 4, 2024 | 03:34 PM
volvodrummer
I know where one of them is. I'll email ya. Maybe he can put you in touch with others if it he can't help.
Old Jun 25, 2024 | 05:14 AM
5 Year Member
I brought the car in for service and they replaced the air bag. The error code went away, but a new air bag related code came up. They are not sure why/where that code is happening, but think there could be a crimped wire somewhere. I had to leave the car at the dealership. Hopefully they'll get it sorted today.
