Coast down misfire correction…….
Old Sep 1, 2024 | 09:48 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Here is a question about the 70 to 20 mph coast down. Went you get to 70 mph and coast down to 20 does the cars ecu understand what you are doing or is there something you need to do first? When I do the coast down I do it at least 4 times. Any thoughts would be helpful. I am thinking I am doing something wrong but can’t figure out what.
Old Sep 2, 2024 | 05:44 AM
handyman2009's Avatar
Veteran: Canadian Forces
According to what I have read, you should be going in a straight line, A/C should be off and you can't touch the brake. The first time you do it the car will feel like it is shaking a lot but the next few time it will feel more normal then you know it has worked. At least that what I have been doing for the past 8 yrs without any issues, good luck.
Old Sep 2, 2024 | 07:34 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
The official coast down procedure is 70 to 40 mph. Going to 20 is unnecessary and just prolongs the process. I've had it complete in as few as three runs if everything is perfect. If you have a foxwell scanner you can watch if "36-1" in the primary PCM flips to complete during each run. As soon as it does you're done.
Old Sep 2, 2024 | 11:29 AM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
here is the procedure
https://www.6speedonline.com/forums/...9&d=1354817796
i have an AMDS, and there were no misfire parameters stored when i purchased the car.
did the procedure once as specified and achieved "learned"
did it a second run...it generated fault codes
i guess once it says "learned" it means it
i think you have to clear the parameters before doing the procedure. once the "learned" flag is set, it won't be triggered to learn them again
just what i surmise from my single experience
Old Sep 4, 2024 | 11:51 PM
M32's Avatar
M32
M32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond repute
Agree and I also read that the car should be warmed up before you start the re-learn procedure
Edwin
Argus
May 26, 2022 09:08 AM
mikhail1
Cayenne 955/957
10
Oct 9, 2012 03:53 PM
boca996tt
American Muscle
Aug 9, 2010 08:29 PM
GL996TT
Feb 19, 2008 09:00 PM
