Rapide lowering springs
Old Dec 18, 2025 | 09:39 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Good morning fellow Rapide owners,
I am contemplating installing lowering springs on my 2010 Rapide, but I can't find any supplier for the 2010 MY.
Has any of you found and installed lowering springs on an early Rapide?
What is your feedback?
Thanks in advance!
Old Dec 18, 2025 | 06:58 PM
J doubleU's Avatar
Your best bet is call Stuart at Velocity and ask if they could do a set. I'd hate to find some sourced ones that say they will work and you end up with a sacked out poor looking ride height issue.
Old Jan 4, 2026 | 08:07 PM
EJ_Rapide's Avatar
Thank you for the reply.
I reached out to VAP, H&R and a couple of other places... but no luck... bummer!
Old Jan 5, 2026 | 10:24 AM
andratch's Avatar
andratch has much to be proud ofandratch has much to be proud ofandratch has much to be proud ofandratch has much to be proud ofandratch has much to be proud ofandratch has much to be proud ofandratch has much to be proud ofandratch has much to be proud of
I suspect your best bet is going to be coilovers. They are more expensive than just springs by a good amount, but are a full bolt-in replacement and some even come with a nose-lift feature that is desperately needed on these cars when lowered.
https://shop.redline360.com/products...RoCl2YQAvD_BwE
Coilovers don't work with the OEM adaptive suspension, so you'll need to code it out or install one of the cancellation kits:
https://madnessautoworks.com/start-s...zUYKwn2IUXXkp0
Old Jan 5, 2026 | 11:43 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
You've seen this thread?: https://www.6speedonline.com/forums/...coilovers.html
Seems brilliant. Keeps your adaptive damping, relatively low cost.
Old Jan 5, 2026 | 12:04 PM
EJ_Rapide's Avatar
Thank you!
rolltide0323
Jun 3, 2018 11:28 AM
bigfish1
Mar 24, 2013 12:51 PM
lovethesport
Cayenne 955/957
Jul 23, 2010 10:16 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
