How to get a vantage into neutral
Old Apr 20, 2026 | 07:19 PM
LALEX1's Avatar
LALEX1 is infamous around these parts
Does anyone know how to get a 2011 vantage sportshift into neutral with no way to get power to the car.
car has a damaged wiring harness so paddles and buttons won’t work.
Old Apr 22, 2026 | 01:39 PM
MRCW's Avatar
never thought about this... interested in responses
Old Apr 23, 2026 | 10:59 AM
embdenb's Avatar
I would think you have to disconnect the shift cables at the transmission and move the shift arms manually
Old Apr 24, 2026 | 11:05 AM
LALEX1's Avatar
For anyone who might need this. This is what Chris from VAP told me.
Hello, if you cannot use the paddles on steering wheel or the N button in dash, only other way is to drop the transmission, remove the shifter and slide over the shifter fork. It might be possible to pin the TCU at connector but would need to know resistance of the circuit for when the N button is pressed and simulate a switch pressed at the TCU connector.
Kind regards,
Christopher Edgett”
Prefurbia
Dec 16, 2025 10:13 AM
arne0072
Apr 1, 2024 06:47 PM
Sir Rothschild
Feb 10, 2024 10:55 AM
LμL
Mar 13, 2023 10:05 PM
Prefurbia
Oct 15, 2021 10:26 AM
