Audi Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
SPM By Alcon A3 (8P) Big Brake Kits from GMP Performance
Old Nov 11, 2013 | 12:11 PM
GMP Performance's Avatar
Site Sponsor
Steve Petty Motorsports, famously known for their exhaust systems for VWs and Audis, have ventured into some new territory for their Audi clientele. That territory is brakes!
Introducing SPM Big Brake Kits!
Steve Petty Motorsports (SPM) and Alcon Components ltd. (Alcon) have joined forces to introduce the ultimate line of direct replacement Big Brake Kits for Audi 8P A3 chassis, featuring the Alcon S-groove rotor design previously only seen in race applications - all for an outstanding price point.
SPM Big Brake Kits will make use of the same Alcon Racing Heritage trusted in F1, World Rally Championship, NASCAR, Grand-Am, LMS and Japanese GT racing. The Alcon brand is world-renowned for providing ultimate braking performance solutions both on and off the track.
SPM is the first to bring Alcon’s latest technology, the S-groove rotor design, exclusively to the VW and Audi market in the USA.
Audi A3 8P SPM By Alcon 375 x 32mm Mono6 Big Brake Kit
Audi A3 8P SPM By Alcon 395 x 32mm Mono6 Big Brake Kit
Kit Contents:
• 2ea Alcon Calipers
• 2ea Alcon Rotors
• 2ea SPM 6061 Aluminum anodized Hat
• 2ea SPM 6061 Aluminum anodized caliper bracket
• NAS fasteners for hat/rotor assembly
• SPM floating drive assembly
• 10.9 and 12.9 Hardware for caliper installation
• 2ea Goodridge Stainless Steel brake lines
• High performance Motul brake fluid
Alcon Rotors:
Grooves in the surface of a brake disc for high-performance vehicles perform three basic function.
1. Increases initial friction between the disc and pads, producing more ‘bite’
2. Continuously refreshes the brake pad surface by removing debris from the pad
3. Prevents buildup of gas from the phenolics within the pads
The Alcon S-groove goes beyond the performance of the highly successful Alcon crescent grooves by further reducing disc distortion and improving pad to disc contact. The curved form of each S groove produces a longer edge than would otherwise be achieved if the grooves were straight. Also the Alcon S grooves overlap radially, which prevents grooving of the friction material
Alcon additional benefits:
• Exceptionally high strength to low weight iron alloy rotors.
• Directional curved cooling vanes for optimum cooling performance
• The SPM two-piece floating disc system that allows for radial and axial thermal expansion, this expansion extends the service life of the rotor.
Alcon Calipers:
The Mono6 caliper designs call on Alcon’s years of experience designing Mono-bloc calipers for world-class race teams. Mono-bloc calipers are stiffer and lighter than 2-piece bolted together designs and so provide better pedal feel, and overall more consistent performance under the most arduous conditions.
Mono-6 calipers are configured with staggered piston sizes to ensure even pad wear and piston area optimized for each individual application. Internal pressure and dust seals provide piston protection while not having direct exposure to the environment, eliminating the inherent issues with dust boots found on other calipers.
SPM Hats, Brackets and Hardware:
SPM lightweight black anodized 6061 Aluminum hats are pre-assembled to the rotor using SPM’s fastening drive system specifically utilizing NAS hardware. We provide the brackets and all class 10.9 and 12.9 hardware required for installation.
Brake Pads:
SPM and Alcon have specifically chosen pin-mounted Ferodo DS-Performance pads, requiring low threshold pressure, providing quick pad retraction and low noise. Ferodo DS-Performance pads also offer strong cold performance for start up, low dust and are specially formulated for excellent resistance to fade at elevated temperatures to enhance your braking performance.
Stainless Steel Brake Lines:
Custom Goodridge G-Stop PTFE Stainless Steel braided lines manufactured to meet SPM’s length and fitting specifications.
For more information, click the links above or click here. feel free to message us or comment below with any questions!
Old Jan 14, 2014 | 02:17 PM
Site Sponsor
Be sure to message us if you are interested in more information!
ECS Tuning - VW
Aug 20, 2015 03:07 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
