Audi Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
Audi S8 4.0 TFSI V8 APR ECU Upgrade from GMP Performance
Old Nov 11, 2013 | 01:22 PM
GMP Performance's Avatar
Site Sponsor
APR is pleased to present the ultimate ECU Upgrade for the Audi S8 4.0 TFSI V8!
After months of long nights and many hours of testing, developing and more testing, we’re pleased to offer you an ECU recalibration that is second to none. APR’s extensive research and development provides you with a powerful ECU upgrade with no loss of drivability or reliability. Expect faster acceleration, improved throttle response and more power across the entire power band.
APR’s 4.0 TFSI V8 ECU Upgrade is an expertly recalibrated engine control strategy that primarily remaps the engine's operating parameters, within the factory ECU, to provide smooth and reliable power as if intended by the OEM. APR’s ECU Upgrade is developed to work within the OEM and Tier 1 Supplier specifications for engine component stress tolerances and performance specifications. Available in octane-specific variations, APR’s calibrations allow you to take advantage of fuel quality available in your area. APR’s patented EMCS functionality puts the control of your engine’s operation at your fingertips and allows for additional features and options to be installed to your OEM ECU.
APR Stage I ECU Upgrade
The APR Stage I ECU Upgrade gives you higher peak numbers of 647 HP/671 FT-LBS on 93 (R+M)/2 octane and up to 685 HP/679 FT-LBS on 100 (R+M)/2 octane race fuel. As much as +130 HP and +142 FT-LBS of torque are available through the power band! APR’s ECU Upgrade is the best power per dollar modification for the new 4.0 TFSI V8 and gives it just the extra edge these cars lack from the factory without pushing the limits. With factory-like smoothness and drivability, APR’s ECU upgrade will fill the void in an otherwise excellent car.
Acceleration Enhancements:
Beyond power and torque enhancements, APR’s Calibration Engineers were able to increase the acceleration rate of the S8 through other calibrations changes. Ignition delay is reduced resulting in a more responsive pedal without altering overall throttle sensitivity. Furthermore, drivability was greatly improved by reducing the throttle lag commonly noticed at slow speeds and while reapplying throttle after decelerating.
Increased Fuel Economy:
APR’s Calibration Engineers paid close attention to several parameters directly related to fuel economy, especially while cruising at highway speeds. Depending on your driving style and fuel quality, you may see better miles per gallon!
Speed Limiter:
APR’s ECU upgrade increases the vehicle's top speed limiter for blistering sprints around the track or across the Autobahn without the speed limiter shutting down your fun!
Left Foot Braking:
APR's Left Foot Braking feature allows more control over the vehicle’s throttle. The factory equipped S8’s throttle input is disabled while pressing the accelerator and brake at the same time. Left Foot Braking, a common motorsport driving technique, allows the driver complete control over the vehicle’s throttle and braking system, which may give the S8 the edge it needs at the track. As is with all features APR adds to the ECU, this feature may be removed upon request.
Crank
Wheel
Gain
APR EMCS Programs and Features
APR’s patented EMCS, Enhanced Modular Chipping System, brings selectable programs and features to your factory ECU, all without the need to purchase external hardware. Other companies have attempted to imitate EMCS with clumsy external switching devices that only replace or multiply portions of a “base” calibration. However, EMCS has the ability to completely rewrite the entire operating map data, giving each map a complete set of calibration changes. APR’s EMCS features and programs modes are activated via your OEM cruise control buttons. Your cruise control will continue to function as normal.
Program Switching:
Program switching allows the user to cycle through up to four different engine calibrations and operating modes all without the need for external hardware.
Stock Mode:
By selecting stock mode, the ECU calibration is reset to the factory calibration. The engine will run exactly as it did before purchasing APR software.
APR Performance Modes:
APR's octane-specific calibrations are available for various premium and race fuels around the world. Each performance mode is a completely new calibration, altered specifically for the characteristics of the fuel quality selected.
Valet Mode:
APR's Valet Mode protects your vehicle from becoming an expensive toy for unauthorized individuals. By enabling Valet Mode, the vehicle's performance is extremely limited. Launch control is uneventful, the vehicles top speed is limited to roughly 40 MPH and the engine's redline is reduced to nearly 5,000 RPM!
Fault Code Erase:
Fault code erase allows the user to erase and reset engine related trouble codes and ECU adaptation data without using a specialty tool.
Security Lockout:
Security lockout prevents unauthorized individuals from using APR's EMCS functionality. When enabled, APR's EMCS features will appear completely invisible until a user specified 2 to 4-digit security code is entered.
Anti-Theft:
When activated, Anti-Theft prevents the engine from starting even if the factory key is used. The vehicle will be completely immobilized until a user specified 2 to 4-digit security code is entered.
The APR Development Difference
APR ECU Explorer:
APR’s proprietary ECU Explorer gives APR’s Calibration Engineers unparalleled access to the vehicle’s entire engine management system. Typical commercially available data logging tools, used by most tuners, only allow logging up to 12 engine-operating variables at extremely low data rates. These tools are also limited to a small, specific list of variables. APR’s ECU Explorer is capable of logging every variable found within the ECU. It’s capable of logging well over 100 variables at once with data rates as high as 100 samples per second. Synchronous data logging is available for fine-tuning.
APR ECU Composer with APR Live Tuning:
APR’s proprietary ECU Composer is used for altering the engine management system. With full access to every table, map and variable within the ECU, APR’s Calibration Engineers are not limited to a handful of maps as is common for most tuning companies. ECU Composer takes calibration to a new level on the 4.0T with APR's Live Tuning. APR’s Calibration Engineers can test calibration changes with a single click of a button to instantly monitor the changes, rather than spending several minutes shutting down the vehicle to reflash the ECU. This allows a level of fine-tuning unmatched in the market.
APR ECU Assembly:
APR’s Electrical Engineers have the ability to alter the code structure of the ECU to add features not available from the factory. Through code levels changes, APR's Engineers are able to add features designed to protect the gearbox during launch control. Other changes allow higher torque limit than those achievable through only modifying calibration data or using piggyback devices as is the case for many tuners. On the highly modified end, this allows APR to make Stage III Turbo Upgrades operate as if intended by the OEM. For most 4.0 TFSI owners, the advantage of this ability is the addition of APR’s patented EMCS Functions. EMCS puts the control of the engine’s operation at your fingertips and allows for additional features and options to be installed to your ECU.
ID:	299302   Click image for larger version
ID:	299303   Click image for larger version
ID:	299304   Click image for larger version
ID:	299305   Click image for larger version
ID:	299315   Click image for larger version
ID:	299316   Click image for larger version
ID:	299317   Click image for larger version
ID:	299318   Click image for larger version
Old Jan 14, 2014 | 02:27 PM
Site Sponsor
Be sure to message us if you are interested in more information!
Jul 29, 2019 11:13 AM
stevenrmusic
Bentley
17
Nov 12, 2015 05:53 PM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
