Audi Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
:: ECS Tuning :: 2 Piece Rear Brake Rotors for Audi B8 S4/S5/Q5!
Old Jan 21, 2014 | 03:08 PM
ECS Tuning - Audi's Avatar
ECS Tuning - Audi is infamous around these parts
Reduce weight. Reduce heat. Reduce warping.
ECS Tuning engineered 2-Piece semi-floating rotors offer real world benefits that can be felt on both the street and track!
Our 2-Piece rotors combine the advantages of weight savings and rapid heat dissipation to provide a rotor superior to stock while preventing warping and extending component life.
The reduction of unsprung weight improves handling characteristics under all situations. This reduction in rotational inertia allows for quicker acceleration, decreased braking distances, and more responsive handling.
Features include:
  • Aluminum hats: To save weight, each rotor ring is bolted to a lightweight aluminum hat made from high quality 6061 aluminum, and hard anodized with an attractive matte black finish that is both durable and corrosion resistant.
  • Gray cast iron rings: Long known for its wear resistance and stable friction characteristics, cast iron is favored for brake rotors due to its ability to absorb and dissipate large amounts of heat.
  • 2-Piece construction: Conventional rotors are unable to cope with the stress of drastic heat fluctuations and are prone to warping. ECS 2-Piece semi-floating rotors allow the radial expansion of the rotor ring - preventing warping.
  • Heat treated: Heat treating further reduces the tendency for rotor cracking by reducing internal rotor stresses.
  • Directionally veined: Conventional S4/S5/Q5 rotors are curved-veined only going one way so heat is dissipated much faster on one side than the other, and rely on an inefficient centrifuge-like effect to evacuate hot air from within the rotor. ECS 2-Piece rotors feature directionally curved veins, directional veins accelerate air away from the rotor at a higher velocity, leading to consistent, rapid cooling on both side equally.
  • Drilled and slotted: 2-Piece rotors are cross drilled to promote cross ventilation for improved cooling as well as slotted to clean brake pads and carry away water and brake dust. Cleaner brake pads result in faster, more consistent stopping. Drilled holes are chamfered while slots are machined with a ball end mill - both to prevent cracking that may be present on improperly machined rotors.
  • Overall weight savings: This particular ECS 2-Piece rotor weighs only 13.5 lb compared to a stock S4/S5/Q5 rotor (16.5 lb). Lighter rotors reduce unsprung weight and rotational mass to improve both braking and suspension performance.
  • Manufacturing quality: Non-friction ring surfaces, including internal vents, are painted to resist salt and other corrosives. Ground braking surfaces ensure rings run parallel, and pads bed easily.
Stopping Never Looked So Good.
Click HERE to order or for more information
Fits:
Make(s): Audi
Model(s): S4 / S5 / Q5 3.2L
Chassis: B8
Ready for a re-ring? ECS offers discounts on pairs of replacement rotors to the original customer or customers showing proof of ownership. Please contact the Sales Department for additional information.
Let me know if you have any questions.
Jason
ID:	323667   Click image for larger version
ID:	323668   Click image for larger version
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
TrackOne
Aug 20, 2015 12:56 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
