Audi Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
The P3 Cars Vent Integrated Gauge for the B5 A4/S4/RS4 from GMP Performance
Old Jul 24, 2014 | 11:06 AM
GMP Performance's Avatar
Site Sponsor
Introducing the all new P3 Cars Vent Integrated Digital Gauge for the B5 A4, S4, and RS4. When you want to truly connect to Audi in every way you can, P3 is here for you. Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior. And since they are specifically designed for each model, you can rest assured that it will fit seamlessly, as if it belonged there all along.
Plug and Play install
Quick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector.
Boost/Vacuum Display
High resolution boost/vacuum via diag port for FAST install. Optionally read boost via boost tap (not included).
Multiple Gauge Displays
Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
Peak Recall & Run Record
Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
Universal Aux Inputs
Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
On the Fly Configuration Menu
Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
We have one of these installed on our own Audi B7 A4 track car and we love it!
If you're interested in more information, click here or feel free to send us a message!
PorscheEnthusiast
Nov 13, 2015 02:23 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
oddjob142
Aug 19, 2015 12:27 PM
