Audi Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
4WheelSpacers.com::2022 Audi RSQ8 Lowered with Wheel Spacers
Old Sep 20, 2022 | 10:10 AM
4wheelspacers's Avatar
5 Year Member
4wheelspacers is infamous around these parts
Recently, here at the 4WheelSpacers headquarters, we had a 2022 Audi RSQ8 come in the shop for lowering and had the chance to test some of our own spacer setups on it.
We were going for a flush fit which proved to be harder than it seems given these vehicles are equipped with the Audi Adaptive Air Suspension and Audi Drive Select allowing the vehicle to regulate its ride height. Furthermore, we equipped a new set of lowering links to the car to allow for an even lower ride height which helps the 23" wheels stand out more.
This being said, we managed to find the right setup to achieve that flush and aggressive look without having any sort of rubbing issue whatsoever.
Here you will find pictures of the 2022 Audi RSQ8 fitted with the factory 23" wheels and lowering links running our own set of 18mm spacers on all four corners to achieve that PERFECT FLUSH LOOK.
Note that the vehicle is set to the lowest possible ride height setting for the pictures.
GET 10% OFF YOUR ORDER WITH COUPON CODE: "AW10" ON OUR WEBSITE AT CHECKOUT!
4WheelSpacers' 18mm Audi Spacer Kit on 2022 Audi RSQ8 front & rear.
2022 Audi RSQ8 stock hub (without Spacers).
4WheelSpacers' 18mm Audi Spacer Kit on 2022 Audi RSQ8 hub.
http://www.4wheelspacers.com/
4WheelSpacers Your #1 Source For The Best European Wheel Spacers and Adapters -SUMMER SALE ON LOTS OF PRODUCTS - QUALITY HUB CENTRIC WHEEL SPACER KITS FOR AUDI, BMW, MBZ, PORSCHE, VW 5MM UP TO 40MM !!!
EMAIL: INFO@4WHEELSPACERS.COM
WEBSITE: WWW.4WHEELSPACERS.COM
SpeedLimit?
Audi
Jul 8, 2008 02:25 AM
Falgo
Audi
Jul 3, 2005 09:17 AM
