Sponsored By:
Sponsored By:
S5 Brembo BIG Brake Kit, PES
Old 02-23-2009 | 03:07 PM
Sercan's Avatar
Sercan has a spectacular aura aboutSercan has a spectacular aura aboutSercan has a spectacular aura about
Nice.
Old 02-23-2009 | 03:31 PM
Patrick - PES's Avatar
Patrick - PES is infamous around these parts
Originally Posted by Gary II
The MTM brake kit is essentially the OEM Audi RS4 8-piston calipers pieced together with some 2pc. discs. I believe the discs are from PFC although I'm not sure who makes the bells/hats.
The Brembo brake kit is a 6-piston Monobloc caliper specifically developed for aftermarket high use (not an OEM caliper used in a different application) specifically engineered for the Audi S5. The piston diameters and disc diameters are selected specifically for that application. Everything is 100% engineered, developed and manufactured by Brembo.
There is a huige difference compared to the OEM S5 brakes...you reduce unsprung and rotational weight, improve pedal feel and modulation, increase heat capacity and temperature management (virtually eliminating fade and all other heat related issues), decrease stopping distances, improved handling, etc...
If you dont have a good job you can come be a sales man for me... haha you cant say it better than that sir.
Old 02-23-2009 | 03:45 PM
Yupkwondo's Avatar
Yupkwondo is infamous around these partsYupkwondo is infamous around these partsYupkwondo is infamous around these partsYupkwondo is infamous around these parts
Ok so my question is....Would this be an improvement over the 8 piston RS4 kit, on a RS4? Or does Brembo offer a kit for the RS4?
Old 02-23-2009 | 04:02 PM
Gary II's Avatar
Gary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of light
It would not be an improvement on the RS4 because it is essentially the RS4 brake system with a different brand of discs. I would have to guess that they use the PFC brand discs so they can manufacturer, or request hats/bells that fit the intended application. Another issue is that the RS4 caliper is not the greatest choice for aftermarket/high performance due to very limited pad options.
At this time Brembo does not produce an aftermarket kit for the RS4 due to very few requests and a lack of genuine interest. If there were sufficient interest, we would manufacturer one, and it would undoubtedly offer all of the improvements that I mentioned for the S5 brake kit. Because of Brembo's OEM relationship with Audi, and the amount of R&D and testing that goes into OEM production, we already start out leaps and bounds ahead of any aftermarket manufacturer. It's one of the reasons why we are able to realize such great performance gains in cars that are already equipped with what many would say are phenominal brakes to begin with. (IE: Porsche, Ferrari, BMW, MBZ, Aston Martin, Nissan, etc...)
Old 02-25-2009 | 05:56 AM
LittleDevil's Avatar
LittleDevil is infamous around these parts
Did you catch it to take some photos. And please let me know what are those wheels?
Old 02-25-2009 | 07:31 AM
Here are some more pix, I hope this helps. Its been to nasty outside to take any good pix. We will have some track footage soon though.
Old 02-26-2009 | 12:29 PM
Thanks for pics!
Which brake fluid is in our cars DOT4? Which brake fluid do you recomend?
Old 02-26-2009 | 12:39 PM
ya, we use dot 4. Any name brand will work but for racing go with a product like SRF or something with a high boiling point.
Old 02-26-2009 | 12:41 PM
thanks! one more question. Is there any sensors on original brakes (brake pads)?
Old 02-26-2009 | 12:46 PM
Gary II's Avatar
Top 5 fluids:
(not in any particular order)
Motul RBF 600
Castrol SRF
Brembo EVO 500 (and also the higher end LCF 600)
ATE TYP 200 - Amber (same as ATE Super Blue without the dye)
AP 551
All of the brake fluids above are great and most drivers will never be able to tell a difference with fresh fluid. The key is keeping the fluid fresh. Brake fluid is hygroscopic and absorbs moisture even out of the air.
Once a bottle is open, use it or lose it.
Throw away any open containers regardless of how much is left.
Do not leave the reservoir open any longer than it takes pour in the brake fluid.
Flush the entire brake system regularly. (I flush every 5000 miles or 3 track events)
The higher end fluids do tend to have less compressibility which translates to better pedal feel, but are also more hygroscopic than the others. The higher up the food chain you go (Brembo LCF600 vs. Brembo EVO500) you will need to flush more often. Also, if your vehicle sits for long periods of time without use, you should ignore the idea of judging mileage or track events and flush the sysetem before any big event.
Old 02-26-2009 | 09:40 PM
Couldnt say it better my self. We used Super Blue in the S5 this time arround.
Old 02-27-2009 | 10:22 AM
GMP Performance's Avatar
Site Sponsor
Email sent patrick. What a coincidence lol ours is black.
Old 04-10-2009 | 12:52 PM
Did you already have track footage? Some pics, videos?
Old 04-10-2009 | 04:13 PM
Ya, I have the footage and it is slated to go up with our new web page. Ill try and throw it up on you tube for the moment but it will take me a day or so.
,Patrick
Old 04-12-2009 | 05:31 AM
AZ Ferrari Man's Avatar
AZ Ferrari Man is infamous around these parts
What are those wheels! Looks amazing!
Quick Reply: S5 Brembo BIG Brake Kit, PES
