ModBargains l STaSIS Alcon Brake Systems l In Stock for your AUDI!! Sweet!!
ModBargains is proud to present to the 6 Speed Online Community: The STaSIS Alcon Brake Systems for your late model AUDI!!!
Are you not satisfied with the braking performance on your Audi? Are you fading your stock brakes? Nothing grabs your attention like an Alcon-based brake system upgrade from STaSIS Engineering! With one look, you can tell that the STaSIS upgrade is going to deliver huge performance benefits while keeping your Audi looking good in the process! [cool]
There's an application for your specific Audi model - Please call me for details, specs, availability, and your pricing!
Applications
Benefits
NO MORE FADE
Higher heat absorption and dispersion
makes for shorter stops turn after turn
IMPROVED PEDAL FEEL
Firm, confidence-inspiring brake pedal because of ultra-stiff calipers, differential piston sizing and stainless steel braided lines.
SAY NO TO WARPED ROTORS
Properly Designed 2-Piece Floating Rotors = Quiet, warp-free performance
QUICKER REACTION TIME
Short, consistent pedal travel can save your life in a panic situation
SHED THE POUNDS
Less weight gives shorter stops, quicker acceleration, improved steering feel and handling
LOWER LONGTERM MAINTENANCE COSTS
Cutting edge design = durable, low-cost system
COMPATIBILITY & EASE OF INSTALLATION
Compatible with ABS and traction control systems with brake bias designed to ensure ultimate gripping power.
All hardware is included to ensure a quick and seamless installation.
What's Included in your STaSIS Alcon Braking System Upgrade
Call me today at (714) 582-3330 x 8004 for the best deals on your next STaSIS Tuning Upgrade for your Audi!
- Eddie -
Applications
- Late model Audis - Please call for details
Benefits
NO MORE FADE
IMPROVED PEDAL FEEL
SHED THE POUNDS
- ALCON 4-Piston / 6-Piston Monobloc Calipers
- ALCON Full Floating Rotors
- STaSIS Caliper Mounting Brackets & Hardware
- Goodridge Stainless Steel Braided Brake Lines
- Motul Brake Fluid(s)
- SBS High-Performance Brake Pads
- Eddie -
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
