Sponsored By:
Sponsored By:
Coolant and Power Steering Fluid Change Intervals?
Old Jan 24, 2011 | 07:31 PM
JTaylorGT's Avatar
JTaylorGT has a spectacular aura aboutJTaylorGT has a spectacular aura about
I have an '03 A4 1.8T and the dealer is suggesting a coolant flush and power steering fluid change. The owner's manual doesn't talk about fluid change intervals other than brake fluid every two years.
Does anyone know the proper change intervals for these fluids?
Old Jan 26, 2011 | 08:33 PM
V8weight's Avatar
V8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond reputeV8weight has a reputation beyond repute
How many miles are on your A4?
Old Jan 27, 2011 | 12:21 AM
Peter1.8t's Avatar
Peter1.8t has much to be proud ofPeter1.8t has much to be proud ofPeter1.8t has much to be proud ofPeter1.8t has much to be proud ofPeter1.8t has much to be proud ofPeter1.8t has much to be proud ofPeter1.8t has much to be proud ofPeter1.8t has much to be proud ofPeter1.8t has much to be proud of
Off the top of my head, I know that g12 is a long life coolant. Most long life coolants suggest you change them at 150k miles. I recently flushed the system on my a4 at 130k just because it looked nasty. If you choose to do it yourself, make sure is g12 or g12+, do not mix those two together. And they should also be mixed 1:1 with distilled water. I guess if it looks anything other than pink kool aid, change it.
Just looked up audi power steering fluid. This source says it should be change every 30,000miles (oops i havent done that in quite sometime) http://www.blauparts.com/audi/audi_f...ng_fluid.shtml
Hope that helps,
Peter
Old Jan 27, 2011 | 11:32 AM
JTaylorGT's Avatar
Thanks guys, my A4 has 68k miles on it. I've owned it for 4 years but never changed either. Because it's a low mileage car (about 6-8k per year), I think time intervals would be the driving factor rather than mileage...
I've heard some independents generalize German cars need both of these every 3-4 years, but was curious on Audi's specifically. My Porsche apparently has 'coolant for life' - don't know if I trust that!
Old Jan 27, 2011 | 12:39 PM
Peter1.8t's Avatar
Just did a little more research, g12 is considered a "life time" coolant. So both your a4 and porsche, apparently, don't need to have it changed. But like I said previously, I flushed mine out just cause it looked murky.
Old Feb 22, 2011 | 02:00 PM
CleverA4PDX's Avatar
CleverA4PDX is infamous around these parts
I drained my Power Steering fluid when I installed my AWE intercooler. I guess it was a good time to do it
Michael_s
Sep 11, 2015 08:03 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Zero911
Aug 24, 2015 06:51 PM
JMon
Aug 21, 2015 08:20 AM
