Sponsored By:
Sponsored By:
Unleash the True Potential of Your Audi RS3 (8Y) with an APR ECU Upgrade!
Old Aug 19, 2025 | 08:36 AM
Nick@APR's Avatar
Nick@APR is infamous around these parts
UNLEASH THE TRUE POTENTIAL OF YOUR AUDI RS3 (8Y) WITH APR!
Product Page
APR ECU UPGRADES FOR THE AUDI RS3 (8Y) ARE HERE!
We're thrilled to introduce APR's Engine Control Unit (ECU) Upgrades for the powerful 2.5 TFSI EA855 EVO engine found in the Audi RS3 (8Y)! With up to 550 HP and 511 FT-LBS of torque, this upgrade transforms your car into a performance powerhouse, delivering exhilarating power and unmatched driving excitement.
Power. Precision. Protection.
Our new ECU software is the result of months of meticulous engineering and real-world testing, far surpassing the typical aftermarket solution. By equipping our development vehicles with high-speed data loggers, turbo shaft speed sensors, thermocouples, and other precision instruments, we fine-tuned hundreds of parameters and corrected countless protection models across multiple octanes to achieve flawless performance, enhanced safety, and unmatched reliability. We're so confident in its reliability that we even offer an optional factory term-limit matching limited powertrain warranty with APR Plus!
What does that mean for you?
It means blistering acceleration with gains of up to +119 AWHP and +135 AWFT-LBS over stock with just tuning alone, and even more with our hardware upgrades! This tuning package delivers a rush of power that transforms your driving experience. With the right surface prep and tires this is a sub 3 second 0-60 car capable of 10 second quarter mile passes that will drop your stomach and pin your back to your seat like never before! You'll enjoy smooth, linear throttle response and a torque curve that feels endless, providing relentless pull across the rev range. Race-proven features like brake boosting and speed limiter removal unlock new levels of control-perfect for track days or spirited driving. All of this is backed by advanced safety routines that ensure your engine remains protected, even under the most demanding conditions.
APR STAGE 1 POWER CHARTS
Performance without compromise
Our ECU upgrade includes advanced safety features that go above and beyond by correcting modeled sensor data within the ECU and enabling and calibrating new protection routines. We've optimized turbocharger protection by monitoring shaft speed and respecting overspinning limits, excessive exhaust backpressure, and unstable pressure ratios. Low-speed pre-ignition (LSPI) protection prevents engine damage in high gears. Thermal management actively reduces power to prevent overheating of critical components and reduces power until your oil reaches the proper temperature. Fuel system optimization ensures safe, reliable operation within critical fueling limits. The result? Massive power gains with the confidence that your engine and drivetrain are protected for the long haul.
b]APR STAGE 2 POWER CHARTS[/b]
Enhanced Driving Experience
We didn't stop at raw power-APR's ECU upgrade enhances every aspect of your driving experience. To truly experience the sound of this engine we open the exhaust valves 100% above 3,000 RPM for sound and power delivery. Furthermore we've calibrated a new light exhaust crackle that's similar to previous factory RS3 models. In park we additionally raised the standing rev limiter to 5,500 RPM, open the valves 100% during revving, and added the exhaust crackle.
Furthermore, we've added left-foot braking and brake boosting for greater control on and off the track, while the speed limiter removal unleashes your car's full top-speed potential. The Auto Start/Stop memory ensures your preferred setting is always ready, putting you in control every time you start the car. Finally, we've recalibrated the boost, power and torque gauges so you can see the full range present at higher power levels!
Features
  • Power Gains: Up to 550 HP / 511 FT-LBS (+153 AWHP / +141 AWFT-LBS)
  • Includes 5 Fuel Grade Tunes: 91 AKI (95 RON), 93 AKI (98 RON), 98 AKI (102 RON), 100 AKI (104 RON), 104 AKI (108 RON), and E60-E85 (no hardware required)
  • Multiple Performance Stages: Specific tunes for use with stock and modified hardware
  • APR Plus: 91 AKI Stage 1 with an optional factory-matching limited powertrain warranty
  • Enhanced Features: Enhanced exhaust note/crackle with fully open valves, increased standing RPM limiter with exhaust crackle and fully opened valves, speed limiter removal, Auto Start/Stop memory, left-foot brake boosting, linear throttle mapping, and unc
  • Advanced Safety Protection Routines: LSPI/knock protection, thermal management, turbo/pressure quotients, and fuel system protection
  • ECU Swap: Our software installs to an unlocked ECU
  • Lifetime Updates: Continuous improvements and support
  • Supports Bolt-On Mods: Adding most hardware upgrades increases power and maximize performance with our software stages
  • No TCU Required: Full torque is unlocked without requiring a TCU upgrade
  • Software 30-Day Money-Back Guarantee
Product Page
HOW TO BUY
This platform is quite different than other ECUs we offer as the ECU needs to be "unlocked" before it can be tuned. Here's the process:
1. Schedule an appointment with an authorized APR Dealer.
2. The dealer will scan your vehicle, and we’ll ship them an unlocked ECU. You can drive home at this point.
3. The dealer will receive the unlocked ECU, schedule you in, install the unlocked ECU, install your APR software, and return your original ECU to us.
You'll pay the dealer for the unlock process and the ECU tune.
Any questions, just ask, call, email, whatever method you prefer!
Go APR
Nick@APR
Lamborghini
Dec 16, 2024 09:36 AM
Nick@APR
Cayenne Turbo
GMP Performance
Audi
Sep 6, 2016 10:36 AM
