Sponsored By:
Sponsored By:
B5 RS4 with MTM 337kw upgrade problems
Old Jun 19, 2007 | 02:26 PM
Oliver Time's Avatar
Oliver Time is infamous around these parts
I'm new to the forum and have enjoyed the wealth of information here.
I wondered if anyone has any ideas for solve a problem I am having.
I recently (March) had an upgrade from MTM 315kw to 337kw. This involved downpipes new cats (100 cell) and a new chip. I already had the catback exhaust.
Since then have been getting "internal resistance too large on B1 and B2 S1" as sporadic errors. I have replaced the Airflow meter, B1 and B2 sensors but still comes up with this error.
Dyno reads 14.5 AFR from 1500 to 4600 rpm when it drops vertically to 10.4
Boost spikes at 25lbs the fluctuates to 21lbs. (1.6 bar to 1.3bar)
I'm not mechanically minded but am led to believe it should be running 12 - 12.1 AFR.
Does anyone know what the MTM dyno reading for AFR (lambda should look like).
Any ideas greatly appreciated.
Old Jun 19, 2007 | 03:22 PM
Kraftwerk's Avatar
3.6TT/2 = 1.8T
Kraftwerk is infamous around these partsKraftwerk is infamous around these parts
MTM tuning always seems to run rich which might explain your car dropping to 10.4:1 but I don't know why it is so lean down low. What does "internal resistance too large on B1 and B2 S1" mean? I've never heard of that fault code and I've had my fair share of codes.
Old Jun 19, 2007 | 03:57 PM
Error codes are P1113 and P1131
Old Oct 25, 2007 | 05:15 PM
lewayhun's Avatar
lewayhun is infamous around these parts
Looks like you need a new car
Marcos AMV8
Dec 18, 2015 06:03 AM
vr6tee
Aug 29, 2015 03:52 AM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
