Subaru STI - Cosworth / APS / 521 WHP Street and Track Capable
Subscribe
Feb 12, 2013 | 09:44 PM
Year: 2004
Make: Subaru
Model: Impreza
Price: $28500
Mileage: 5000
Color: Silver
Location (State): CO
Transmission: Manual
Drivetrain: 4WD & AWD
There were no corners cut with this build. Currently the car has 53,562 and 5,004 miles on the build. The car was tuned by Harvey at the Boostcreep here in Colorado and made 521 whp on e85 at 21 lbs (very conservative tune) and 420 whp on 91 at 19lbs. Again, this is a very conservative tune and given the altitude there is still a lot more potential if you so choose. This car has been built to be a very competitive track car with the ability to be a reliable daily driver. Only the highest quality of parts were used in this build and taking a clean and "sleeper" appearance into consideration. In addition, almost the entire interior was replaced with a more desirable and cleaner black leather interior.
I can go on and on about this car but would rather not write everything out but if you are interested please contact me via PM and we con discuss over email or phone.
I have layed out every mod below.
Engine
- Accurate Machine Works Oil Catch Cans
- APS 3.5in Turbo Back Exhaust
- APS 80mm Cold Air Intake
- APS Billet Aluminum WRX Fuel Rails
- APS Braided Stainless Steel Fuel Rail Lines
- APS Braided Stainless Steel Power Steering Lines
- APS DR725 Front Mount Intercooler
- APS Dual Vent Bypass Valve
- APS Split Pulse Header
- APS Split Pulse Header Exhaust Shields
- APS TSR70 Turbo
- Cosworth Shortblock
- Cosworth 274 Exhaust Camshafts
- Cosworth 278 Intake Camshafts
- Cosworth Big Valve Cylinder Heads
- Cosworth Billet Crankshaft
- Cosworth Billet Timing Belt Guide
- Cosworth Connecting Rod Bearings
- Cosworth Cylinder Head Studs
- Cosworth Forged Pistons
- Cosworth H-Beam Connecting Rods
- Cosworth Main Bearings
- Cosworth Oil Pump
- Cosworth Piston Rings
- Crucial Racing 160 Degree Thermostat
- Crucial Racing Ported Stock Throttle Body
- Crucial Racing Radiator Caps
- Custom Automatic Intercooler Sprayer
- Custom Harmonic Damper
- Two step colder Spark Plugs
- 1000cc Fuel Injectors
- Cobb Accessport Speed density custom tune by Harvey at Boost Creep
- HKS Twin Power DLI Ignition Amplifier
- JDM WRX Tumble Generator Valve Deletes
- Koyo Aluminum Radiator
- Braided Stainless Steel Fuel Lines
- Braided Stainless Steel Wastegate Lines
- Brake Line Heatshields
- Turbo Blanket
- Samco Silicone Radiator Hoses
- Sard Adjustable Fuel Pressure Regulator
- STi Kevlar Timing Belt
- System One Fuel Filter
- Tial 44mm Wastegate
- Thermotec Intercooler Piping Heatshield
Drivetrain
- ACPT Carbon Fiber Driveshaft
- Carbonetic Carbon Triple Plate Clutch
- Driveshaft Shop Level 5 Rear Axles/Hubs/CV Joints
- Kartboy Front Shifter Stay Bushing
- Kartboy Rear Shifter Stay Bushing
- Kartboy Shifter Lever
- Kartboy Transmission Crossmember Bushings
- SPT Short Shifter Mechanism
- Turn In Concepts Shifter Linkage Bushings
- Turn In Concepts Shifter Pivot Bushings
Chassis
- Cusco Motor Mounts
- Cusco Rear Subframe Brace
- Cusco Transmission Mount
- Happi Motoring Fender Cowl Braces
- Kartboy Billet Aluminum Engine Pitch Mount
- Kartboy Exhaust Hangers
- Kartboy Rear Differential Crossmember Bushings
- STi S204 Front Performance Damper
- STi S204 Rear Performance Damper
- STi JDM Transmission Under Panel
- STi Spec-C Titanium Strut Tower Brace
- Turn In Concepts Rear Differential Bushings
- Whiteline Rear Subframe Locking Bolts
- Whiteline Steering Rack Bushings
Suspension
- Cobb Tubular Front Sway Bar
- Cobb Tubular Rear Sway Bar
- Ohlins 25 Way Adjustable Front Struts
- Ohlins 25 Way Adjustable Rear Struts
- Perrin Front Sway Bar End Links
- Perrin Rear Sway Bar End Links
- Racecomp Engineering Front Camber Plates
- STi JDM Spec-C Front Spring
- STi JDM Spec-C Rear Springs
- STi Group-N Rear Strut Mounts
Brakes
- Goodridge Stainless Steel-Braided Brake Lines
- Hawk HPS Front Pads
- Hawk HPS Rear Pads
- The Brakeman 2 Piece Front Rotors
Interior
- 2004 WRX Black Carpet
- 2004 WRX Katzkin Leather Covered Rear Seats
- 2006 STi Center Console
- 2006 STi Steering Wheel & Air Bag
- 2006 WRX Armrest Extension
- 2006 WRX Limited Leather Door Panels
- 2007 STi Limited HVAC Controls
- Autometer Triple Gauge Glove Box Mount
- Autospeed Billet Dead Pedal
- Bazooka 8in Subwoofer Tubes
- Defi Dash Triple Gauge Mount
- Defi Exhaust Temperature Gauge
- Defi Fuel Pressure Gauge
- Defi Link 2 Gauge Controller
- Defi Oil Pressure Gauge
- Defi Oil Temperature Gauge
- Defi Water Temperature Gauge
- Infinity Kappa Perfect 6.1 Front Speakers
- Infinity Kappa 42.5i Rear Speakers
- Kenwood DDX-7017 Head Unit
- Kenwood KDH-C710 Hard Drive Unit
- Kenwood KNA-DV4100 Navigation Unit
- Recaro Sport Black Leather Front Seats
- Redline Automotive Leather Armrest Extension Cover
- Redline Automotive Leather Emergency Brake Boot
- Redline Automotive Leather Shifter Boot
- Rockford Fosgate Power 851 Amplifier
- Rockford Fosgate Power 1001BD Amplifier
- Solar Gard Window Tint
- STi CDM Black Floor Mats
- STi JDM Automatic Intercooler Sprayer Switch
- STi S204 Hazard Button
- STi S204 Shifter Trim
- STi Spec-C V-Limited Shifter ****
- Turbosmart e-Boost 2 Boost Controller
Exterior
- 2005 STi Headlight Housings
- 2005 STi Front Emblem
- 2005 STi Rear Emblem
- 2006 STi Rear Diffuser
- 2006 STi Side Under Panels
- 2007 STi Limited Rear Wing
- 2007 STi Limited Trunk Lid
- Autospeed Billet Front Bumper Trim
- BBS RE 18x8 Diamond Black Wheels
- Car Service Hiro Battle Hawk Carbon Fiber Hood
- Carbign Craft Alternator Shroud
- Clearshield Vinyl Front Bra
- Cusco Stainless Steel Hood Pins
- Gruppe-S Carbon Fiber Radiator Shroud
- GT Spec Carbon Fiber Rear Bumper Heat Shield
- Hella Xenon Blue High Beam Headlight Bulbs
- Kartboy Billet Aluminum Battery Tie Down
- STi S203 Wheel Center Caps
- STi Spec-C V-Limited Front Lip
- STi Spec-C V-Limited Rubber Under Lip
- Trust Aluminum Lug Nuts
Reply
Feb 13, 2013 | 09:59 AM
I dont have enough posts just yet to reply to the PM's if you send me a PM please include your email or phone number. You can also email me at bradleyjmichaels@gmail.com
Reply
Feb 14, 2013 | 10:10 AM
Awesomely built Subi!! GLWS!
Reply
Feb 15, 2013 | 11:07 AM
offers?
Have you recieved any offers as of yet? This car is pretty impressive and for the right deal I'd have a lot of interest
Reply
Feb 15, 2013 | 11:58 AM
I have received multiple offers so far. If you are still interested and would like to discuss price further please email me at bradleyjmichaels@gmail.com
Reply
Feb 22, 2013 | 08:21 PM
Feel free to make an offer
Reply
Mar 31, 2013 | 08:01 PM
why sellin it man? it's a beautiful build.
Reply
Apr 4, 2013 | 01:05 PM
What did the car cost to build all in? That is one impressive list of parts. That car would make a lot of Porsche guys sad at the track, especially in the wet.
Reply
Subscribe
