1995 ECLIPSE GSX TURBO BUILT 2.3 Liter 6 Bolt 400+whp
32 Attachment(s)
GREEN 1995 Eclipse GSX 5spd AWD Turbo
*BUILT 2.3 Liter Stroker* 149k miles This is a great car for someone who wants a cheap fun turbo toy :) It pulls hard, sounds beastly, handles great and stops on a dime with the Baer Big Brake kit. There is also potential to make over 500awhp w/ meth or E85 so it is a lot of car for the money. I just don't have time to enjoy it right now so I'm selling.The car has a lot of money in it and with the recent maintenance already done, you don't have to do anything but drive! I know the previous owner too so it was in good hands prior. Areas Of Concern The biggest concerns are a few rips in the driver's seat, stereo needs the code so it doesn't work (I will throw in the Scosche stereo adapter so you can put in a new head unit), and the A/C belt isn't connected but the entire A/C system is intact. The car looks and feels like it has maybe 80k miles. You won't be disappointed! *** Send me a message if you want to check out and the car and make an offer! *** ENGINE (~3,000 miles on the motor) Block: 2.3 liter stroker -JE Pistons -Eagle Rods -Forged 100mm eagle crank, built to handle 600+hp -All ARP hardware (head studs,etc...) -HKS 264/272 cams RECENT MAINTENANCE -New Oem oil pump (hellical gears, 1000miles ago) -New Oem water pump (1000 miles) -New Oem timing belt and pulleys (1000 miles) -Freshly rebuilt throttle body with new ISC motor -New NGK BPR8ES Plugs -Optima Red Top Battery -Fresh Rotella 15W40 Oil Change (10/18/2013) -WIX Oil Filter (10/18/2013) -Magnetic Oil Drain Plug (10/18/2013) TRANSMISSION -Stock trans shifts like butter! Never launched -Always used Redline MT90 -ACT Unsprung 6 puck with act streetlight flywheel TURBO -FP Red (old school 65lb capable) with steel braided oil feed and fp oil filter/restrictor. Burns zero oil and has no shaft play -38mm Tial Wastegate dumped to atmosphere EXHAUST -Full 3" turbo back exhaust with magnaflow muffler INTERCOOLER -Punishment Racing Intercooler with full aluminum piping -Turbosmart supersonic bov FUEL -Walbro 255 fuel pump+rewire kit -AEM fuel pressure regulator ELECTRONICS -DSM LINK V3 FULL Licensed -Innovate wideband -Autometer egt guage -No name boost guage (all three guages on pillar) -HKS turbo timer BRAKES -BIG Baer track claw Front Brakes (12" drilled/slottled rotors with big dual piston calipers) -Drilled/slotted rear rotors -Coated steel braided goodyear brake lines SUSPENSION/WHEELS -Fittipaldi wheels -Lowered on Koni adjustables and H&R springs VIDS http://s7.photobucket.com/user/Rn304...27a4a.mp4.html http://s7.photobucket.com/user/Rn304...1cd28.mp4.html https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 https://www.6speedonline.com/forums/...ine=1382404487 |
Brings back some memories... it all started with a dsm and I was hooked :)
Good luck with the sale! |
Originally Posted by dgreen78
(Post 3963119)
3 Attachment(s)
