2006 BMW M3 ZCP/IB/Slicktop/6mt/M-Texture/32k Miles Wknd/Track
Old May 16, 2014 | 09:56 AM
audipwr1's Avatar
audipwr1 is infamous around these parts
Year: 2006
Make: BMW
Model: M3
Price: $40000
Mileage: 32500
Color: Interlagos Blue
Location (State): CA
Transmission: Manual
Drivetrain: Rear Wheel Drive
New Pictures Added
2006 E46 M3 Interlagos Blue, ZCP, No sunroof, M-Alcantara Interior, 32k miles, Clean Carfax
I am the third owner
First owner was in NY, Second was in CT – I spoke with both of the prior owners at length prior to purchase. Car was never tracked prior to my ownership, had never been damaged (on or off insurance). It had been broken into and had its navigation system stolen (replaced with standard radio). It had never been driven in the snow (under carriage is 100% rust and corrosion free, all bolts come right undone with proper force, not an east coast road salt mess)
I am considering selling the car, but have put in astronomical amounts of money into turning it into what it is today so am putting out a feeler to see if I should just put it in storage or sell it.
The car was built to be a weekend / track day car.
I purchased the car last April and have done the following since:
Maintenance:
All fluids changed (oil, power steering, coolant, transmission, differential, brakes/clutch)
• Inspected Vanos tabs – no damage at all on hub or tabs (see following post for picture)
• Did valve adjustment – new valve cover gasket
• Replaced Cabin Air filter
• Replaced spark plugs
• Replaced serpentine belt
• Replaced battery
• Replaced engine mounts
• Replaced transmission mounts
• Replaced vanos filter
• New brake pressure sensor 2
• Rebuilt rear calipers
• New ebrake pads
• 2 new 02 sensors
Track-Day Build:
Chassis
• TCDesign half cage
o If you don’t know TCDesign you should research them – best cage and track car builder in the country for M3’s and Porsches
• Reinforced rear subframe
• TCDesign corner balance and aligned
Suspension
• Ground Control Track build shocks
• Ground Control FTAB
• Bimmerworld Spherical RTABS
• Bimmerworld rear adjustable camber arm
• Ground Control Race camber plates (front)
• Ground Control Front Sway Bar (race)
• Ground Control Rear Sway Bar (race)
Interior
• Recaro SPG Profi XL drivers Seat
• Recaro SPG Profi passenger Seat
• VAC floor and side mounts on both sides
• Scroth 6 points camlock harnesses (both driver and passenger)
• Custom radio delete
• Custom rear seat delete
• Extended brake and gas pedal
Performance
• UUC clutch
• UUC lightweight flywheel
Braking
• Bimmerworld Carbon brake ducts
• Bimmerworld brake backing plates
o Fully plumbed brake cooling system – just completed this to keep rotor temperature better maintained
• Front Pads: PCF 08 pads, CarboTech XP 10 Pads, Stock pads
• Rear Pads: Performance Friction Street/Track, OEM ZCP Pads
• 2 sets of rotors (ZCP front and back)
• Brass Caliper guides
• Motul RBF 660 fluid (plus lots of spare bottles)
Tires / Wheels
• ZCP rims on Hankook Ventus tires (new tires, but I believe these are replica rims owner said that he had curbed two of the OEMs and replaced them all through his shop)
• OEM 18inch square, painted black, on RS3’s (track day, 70% tread left)
Spares:
• INPA Cable
• All associated BMW tools (diff plug sprocket, fan bolt wrench, valve shim tool)
• Set of rear ZCP calipers
• Full interior
• Suspension / Sway Bars
• Spare pads and rotors
• Spare 02 sensors
• Valve shims
• Oil change kit
• OEM Diff fluid, Brake Fluid, OEM coolant
• Box of OEM spare parts and fasteners (all common issue parts for the car to bring to track)
• Binder of receipts from most purchases / maintenance etc.
4 Imperfections
• ¼ inch dent on hood
• Light scratch on roof – medium compound orbital brushing should knock it out. I only have a light compound
• Right rear inner tire well had a tire blow out and there is paint damage inside the wheel well from it
o I didn’t touch fixing this yet, but if it were a show car I would – you can’t see it unless you look closely
• Like all these cars the power steering hose weeps (doesn’t make it to floor in terms of rate of leak)
Price is $40k. I am open to a discussion on pricing with interested parties via PM.
Old May 16, 2014 | 09:58 AM
audipwr1's Avatar
audipwr1's Avatar
Old May 16, 2014 | 12:06 PM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
Nice! All that work and you didnt reinforce the subframe?
You should consider holding onto it, going to be hard to get what its worth.
Old May 16, 2014 | 12:20 PM
audipwr1's Avatar
Rear Subframe was reinforced (via welded plates), then cleaned up, at painted to make sure no oxidation would happen
Old May 18, 2014 | 12:15 PM
audipwr1's Avatar
Floor mats are included, I just prefer not to use them given I don't drive it in the rain or any poor weather
ID:	375956   Click image for larger version
ID:	375957   Click image for larger version
ID:	375958   Click image for larger version
Old May 21, 2014 | 07:37 AM
audipwr1's Avatar
Willing to keep the Recaros and Scroth belts to reduce the price. I have the mint manual M-texture seats to replace them with.
Old May 21, 2014 | 06:00 PM
Duff0000's Avatar
Duff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond repute
How much track time has this car had?
Old May 22, 2014 | 10:45 AM
audipwr1's Avatar
5 days, 2 at Somona and 3 at Laguna
cnebrask
Oct 3, 2024 08:19 PM
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
GrantRR
Jun 28, 2018 03:33 PM
