05 FXT 6spd, Brembos, 5x114, 440AWHP, EFR, Built Motor
Old May 15, 2015 | 08:21 AM
fjwheeler's Avatar
fjwheeler is infamous around these parts
SOLD 05 FXT 6spd, Brembos, 5x114, 440AWHP, EFR, Built Motor
Year: 2005
Make: Subaru
Model: Forester
Price: $19500
Mileage: 151500
Color: White
Location (State): TN
Transmission: Manual
Drivetrain: 4WD & AWD
SOLD
This is painful to even post this for sale, but life events (want an RX7) neccesitate. I am the third owner of this BEAUTIFULLY DONE 2005 Aspen White Forester XT with full STI swap. Full parts details to follow! This car was purchased from astro99 here on the forums last year from AL. He had purchased the XT from BIG67 who bought the car new and created a truly special car. I bought the car sight unseen and went to pick it up without a worry. And guess what? I could not have made a better decision! I have enjoyed every minute of this car as it has been my primary daily driver since purchase. Life changes things of course, and I need to let this go on to another to enjoy. I have always wanted to have a nice V8 FD3S and that is the only trade I will be interested in.
Priced at $19,500. Clean title located in Knoxville,TN.
Attachment 542332
So here are the full specs:
2005 Forester XT with huge sliding moonroof, full leather interior.
VIN: JF1SG69635G715535
Body: 151,000 miles as of5/13/2015.
No accidents/flood damage/hail damage/rust/or other shenanigans
This car has lived the majority of its life in California (first owner) or Alabama, while I owned it it only saw snow one time and was promptly detailed. No salty/snowy rust producing weather history here.
Engine:
[Note: the vast majority of the work performed on this vehicle was performed by Kevin Wong at Auto Headquarter Motorsports in CA]
Engine build currently at 57k miles ... flywheel, timing belt, water pump all new at 57K as well.
EJ 257 Sti Block (ACL Race main and rod bearings, CP Stock bore pistons and rings, Eagle Connecting rods with ARP rod bolts)
Turbo Borg-Warner EFR-6758 http://www.full-race.com/store/turbo...758-turbo.html
APS Duel Entry TMIC
Cobb SF Intake
Cosworth Head Gasket
Cosworth Head Studs
Cosworth Oil Pump
Tomei STI AVCS Cams
Cosworth Titanium Valvetrain with Dual Springs
Power Enterprises Timing Belt
Tomei Timing Belt Guide
Okada Project Plasma Direct Ignition Coils
Denso IKH 24 spark plugs
STI Intake Manifold with TGV Deletes
Omni 3-Bar Map
Borg-Warner High Pressure Wastegate Actuator (medium to be included as well)
Grimmspeed Phenolic Intake Manifold Spacers
Subtle Solutions Hood Scoop Splitter
DeatschWerks DW200 Fuel Pump
DeatschWerks Top Feed rails
Bosche EV14 1000cc injectors
STI In Tank Fuel Box(prevents fuel starvation during hard turns)
Exterior Mounted Fuel Filter
Borg-Warner EFR Three Port Boost Controller
E-Viseton Aluminum Radiator
Samco Radiator Hoses
Zerosports Radiator Shroud
Samco Turbo inlet hose
Beatrush Solid Motor Mounts
Full-Race ProStock Exhaust Manifold http://www.full-race.com/store/efr-t...anifold-1.html
Full-Race Stock location EFR Mounting Kit http://www.full-race.com/store/efr-t...rbo-kit-2.html
Invidia G200 Catback
Cobb Accessport with custom tune by MotionLab Tuning in Charlotte, NC. On 93 Octane and 21 PSI made 440AWHP/393lbft. Conservative tune at 85% injector duty cycle and 10.8 AFR.
Drivetrain:
Transmission/hubs/axles current mileage at 96K miles
STI 6 speed transmission from 2007 STI(New model with Wide Ratio Gearing and no oil pump)
ACT Xtremeduty Clutch/Pressure Plate kit new within 3000 miles
STI 5x114.3 Knuckles and Hubs
STI Axles
R180 rear Differential with 3.54 final drive
Welded Rear Differential carrier
Beatrush Solid Trans Mount
Brake, Steering, Suspension:
STI Brembo Calipers F&R (painted black)
Endless Stainless Steel brake lines
Pagid 4-2-1 Front pads installed less than 1000 miles ago
Mintex Rear Pads
Cusco Zero 2-E coilovers
Swift Coilover springs 9k Front, 7k Rear
HKS Kansai Aluminum Front Subframe
IKEYA Concepts Solid Rear Subframe bolts
Front strut tower bar (not installed on pics but will be included)
Cusco carbon fiber rear strut tower bar
Cusco Front and Rear Sway Bars
Zero Sports Roll center adapters (ball joint extenders)
Whiteline Anti Lift Kit
STI aluminum control arms
STI Lateral Links
STI Steering Rack
STI Power Steering Pump
Whiteline Steering Rack Bushings Brand New as of last month.
STI Gold BBS wheels
255/40/17 Hankook RS-3 Tires Purchased in March of this year. Less than 3000 miles on them.
Project KICS Aluminum Wheel Spacers
Brand New Outer Tie Rod Ends last month
Interior:
Kenwood DDX371 Head Unit
Hertz HSK 163 mids with 165 tweets
Hertz 10” sub in custom enclosure
Full Rammat Sound Deadening
Full Size Spare Tire
Subaru Homelink Self Dimming Rearview Mirror
Clifford Alarm System with Remote Start(MT safety installed) (Currently disabled. Needs one wire hooked into fuel injectors wiring.)
Audison Amp (fantastic sound setup that I will sorely miss almost as much as the performance aspects of the vehicle)
AEM UEGO AFR Gauge (hidden in ashtray pocket.)
MoBoost Steath Boost Gauge (Freaking SLICK setup)
Exterior/Other:
TRS Projector Conversion with Morimoto HIDs
Gorilla Mudflaps
Subtle Solutions front license plate delete
Subtle Solutions rear exhaust protector
Curt hitch (hidden well, can't really see it unless really looking for it, only used for bike rack attachment)
Tint (35% and professionally installed in 2013)
Tinted Taillights
The GOOD: This car NEEDS NOTHING. There are no engine codes, warning lights, etc. Oil change (Millers Race Oil) and full transmission fluid change (factory Subaru 75W-90) performed within the last 2000 miles. It's fast, handles like an absolute dream, and doesn't beat you up if you are just making a grocery store run or picking up the kids from school. This was my daily driver. No track days, dragstrips, but I autocrossed it about 5 times and made a couple dragon runs. It was basically an overbuilt sleeper for my needs! If I wasn't ready to buy a RX7 I wouldn't be selling. This car is incredible the boost comes on faster than a VF43 and makes torque like you wouldn't believe. Every time someone rides with me they are blown away.
The BAD: I'm picky, and I do wish the body was in a little better shape. It has a number of small dings around the body. The worst section is the area of the right rear bumper, but the car has NEVER been in an accident. Hey, I think it actually looks great for a Subaru body with 100k+ miles, but I want you to know the body is not a 9 or 10/10 by any stretch. The windshield is also original but can be replaced for an additional $250, but that can be discussed with a potential buyer when the time comes.
In summary, this car is basically a low miles STI with a Forester body. There isn't much left besides body panels and interior that is stock. I never worry about getting in and going for a drive and on the interstate I see consistent 21mpg. To duplicate this build would cost you over $50,000. I bought the car wanting to have the most fun Forester you could have. I feel I have succeeded. On roads like the Dragon there isn't much that hangs on, and at autocross I am beating Gen 1 Elises and fully prepped STIs. I don't want to sell the car, in a perfect world I would have space for another car in my driveway, but I do not therefore the FXT has to go.
All spare parts will be included, including mats, luggage covers, owners manual, spare keys, and anything else I can find laying around.
Attachment 542332
Old May 15, 2015 | 09:03 AM
Nura's Avatar
Nura is infamous around these parts
Now this is something special! GLWS.
Old May 15, 2015 | 12:41 PM
Twelvz's Avatar
Twelvz is just really niceTwelvz is just really niceTwelvz is just really niceTwelvz is just really niceTwelvz is just really nice
Very cool. I'd rock one of these.
Old May 18, 2015 | 12:33 PM
fjwheeler's Avatar
Sold
the5
Oct 14, 2015 06:46 AM
longboarder
Sep 12, 2015 12:55 AM
ricks234
Sep 10, 2015 12:51 PM
